Kubeflow
Channel Revision Published
latest/beta 430 30 Aug 2024
latest/edge 438 30 Jun 2025
1.10/stable 440 05 Aug 2025
1.10/candidate 441 05 Aug 2025
1.10/beta 433 24 Mar 2025
1.9/stable 432 03 Dec 2024
1.9/beta 420 19 Jul 2024
1.9/edge 431 03 Dec 2024
1.8/stable 414 22 Nov 2023
1.8/beta 411 22 Nov 2023
1.8/edge 413 22 Nov 2023
1.7/stable 409 27 Oct 2023
1.7/beta 408 27 Oct 2023
1.7/edge 407 27 Oct 2023
juju deploy kubeflow --channel 1.10/beta
This guide describes how to serve a BERT model using NVIDIA Triton Inference Server.
Refresh the knative-serving charm
Upgrade the knative-serving charm to channel latest/edge:
juju refresh knative-serving --channel=latest/edge
Wait until the charm is in active status, you can check its status with:
juju status --watch 5s
Create a notebook
Create a Kubeflow Notebook to be used as your workspace. Leave the default notebook image, since you will only use the Command Line Interface (CLI) for running commands.
Running commands in this guide requires in-cluster communication, meaning instructions only work within the notebook environment.
Connect to the notebook, and start a new terminal from the launcher:
Use this terminal session to run the commands in the following sections.
Create the Inference Service
Define a new Inference Service YAML file for the BERT model as follows:
cat <<EOF > "./isvc.yaml"
apiVersion: "serving.kserve.io/v1beta1"
kind: "InferenceService"
metadata:
  annotations:
spec:
  transformer:
    containers:
      - name: kserve-container
        image: kfserving/bert-transformer-v2:latest
        command:
          - "python"
          - "-m"
          - "bert_transformer_v2"
        env:
          - name: STORAGE_URI
            value: "gs://kfserving-examples/models/triton/bert-transformer"
  predictor:
    triton:
      runtimeVersion: 20.10-py3
      resources:
        limits:
          cpu: "1"
          memory: 8Gi
        requests:
          cpu: "1"
          memory: 8Gi
      storageUri: "gs://kfserving-examples/models/triton/bert"
EOF
In the ISVC yaml, make sure to add the annotation "sidecar.istio.io/inject": "false". Due to issue GH 216, you will not be able to reach the ISVC without disabling istio sidecar injection.
Schedule GPUs
For running on GPUs, specify the GPU resources in the ISVC YAML file. For example, you can run the predictor on NVIDIA GPUs as follows:
cat <<EOF > "./isvc-gpu.yaml"
metadata:
spec:
  transformer:
    containers:
        command:
          - "python"
          - "-m"
        env:
          - name: STORAGE_URI
  predictor:
    triton:
      resources:      # specifiy gpu limits and vendor
        limits:
          nvidia.com/gpu: 1
        requests:
          nvidia.com/gpu: 1
EOF
See Schedule GPUs for more details.
Now you need to modify the ISVC YAML file to set the node selector, node affinity, or tolerations in the ISVC to match your GPU node.
For instance, this is an ISVC YAML file with node scheduling attributes:
metadata:
spec:
  transformer:
    containers:
        command:
          - "python"
          - "-m"
        env:
          - name: STORAGE_URI
  predictor:
    nodeSelector:
      myLabel1: "true"
    tolerations:
      - key: "myTaint1"
        operator: "Equal"
        value: "true"
        effect: "NoSchedule"
    triton:
        limits:
          nvidia.com/gpu: 1
        requests:
          nvidia.com/gpu: 1
EOF
This example sets nodeSelector and tolerations for the predictor. Similarly, you can set the affinity.
Now apply the ISVC to your namespace with kubectl:
kubectl apply -f ./isvc.yaml -n <namespace>
Since you are using the CLI within a notebook, kubectl is using the Service Account credentials of the notebook pod.
Wait until the Inference Service is in Ready state. It can take up to few minutes. Check its status with:
kubectl get inferenceservice bert-v2 -n <namespace>
You should see an output similar to this:
NAME      URL                                           READY   AGE
bert-v2   http://bert-v2.default.10.64.140.43.nip.io   True    71s
Perform inference
Get ISVC status.address.url:
URL=$(kubectl get inferenceservice bert-v2 -n <namespace> -o jsonpath='{.status.address.url}')
Make a request to this URL:
  • Prepare the inference input:
cat <<EOF > "./input.json"
  "instances": [
    "What President is credited with the original notion of putting Americans in space?"
EOF
  • Make a prediction request:
curl -v -H "Content-Type: application/json" ${URL}/v1/models/bert-v2:predict -d @./input.json
The response contains the prediction output:
{"predictions": "John F. Kennedy", "prob": 77.91851169430718}
Help improve this document in the forum (guidelines). Last updated 9 months ago.
