Kubeflow
- Kubeflow Charmers | bundle
- Cloud
| 1.10/stable | 440 | 05 Aug 2025 |
| 1.10/candidate | 441 | 05 Aug 2025 |
| 1.10/beta | 433 | 24 Mar 2025 |
This guide describes the general steps required to install Charmed Kubeflow (CKF).
CKF can be installed on any CNCF certified Kubernetes (K8s), including Canonical Kubernetes, AKS, EKS, GKE, Openshift, and any kubeadm-deployed cluster.
Requirements
Charmed Kubeflow requires a running K8s cluster with the following:
- Kubernetes version depending on the CKF version you are deploying. See Supported versions for more details.
- A default storage class configured.
Bootstrap Juju
CKF is deployed to Kubernetes with Juju. Before deployment, Juju must be bootstrapped to the K8s cluster. For bootstrapping instructions, see Get started with Juju.
Create the kubeflow model
To create a Juju model for CKF, run:
juju add-model kubeflow
The model name must be kubeflow.
See Juju OLM | add-model for more details.
Deploy CKF
To deploy the most recent stable version of CKF, run:
juju deploy kubeflow --trust
You can install a different version of CKF by using the --channel option. See Supported versions for more details.
It may take up to 20 minutes for all charms to become active.
You can monitor the deployment status with Juju as follows:
juju status --watch 5s
Access CKF dashboard
You can interact with CKF using its central dashboard, accessed through an IP address. To access it, you must:
- Configure Dex to authenticate with the Identity Provider of your choice.
- Find the dashboard’s IP address.
Configure Dex
To configure Dex’s built-in connector, set credentials by configuring dex-auth with a username and a password:
juju config dex-auth static-username=<new username>
juju config dex-auth static-password=<new password>
To use an external Identity Provider, see Integrate with identity providers for more details.
Find the dashboard IP address
If the deployment uses a LoadBalancer, you can find the dashboard’s IP by running the following command:
kubectl -n kubeflow get svc istio-ingressgateway-workload -o jsonpath='{.status.loadBalancer.ingress[0].ip}'
See kubectl get for more details.
If you have configured Istio Gateway to use a different gateway service type such as ClusterIP or NodePort, the dashboard should be accessible at that service’s IP. See Istio Gateway configurations for more information.
If DNS is required, use the resolvable address from istio-ingressgateway.
To access the dashboard remotely, you can obtain the IP over SSH and a SOCKS proxy. See How to set up SSH for more details.
Log in
Once you have accessed the dashboard IP address, log in using the credentials matching the identity provider you are using.
