Hardware Observer
- By Canonical BootStack Charmers
latest/stable | 59 | 03 Apr 2024 | |
latest/candidate | 70 | 06 May 2024 | |
latest/edge | 70 | 06 May 2024 |
juju deploy hardware-observer --channel edge
Monitor hardware RAID controllers
The command-line utilities managing the RAID controllers need to be manually downloaded and then uploaded to the charm via the juju attach-resource
command (except for SSACLI which is automatically downloaded).
You can use the command-line utilities provided by the resource as mentioned in the Resources page.
For example, to add the “perccli-deb” resource to the charm:
Go to the Resources page, and find the name of the tool along with the URL where it can be downloaded from the manufacturer’s site.
Download the binary tool in x86_64 linux architecture.
(Optional) Unzip and extract the content from the file obtained in the previous step.
Attach the resource to the charm with
juju attach-resource hardware-observer perccli-deb=<path-to-resource>
Other resources can be added similarly.
