Hardware Observer
- By Canonical BootStack Charmers
latest/stable | 59 | 03 Apr 2024 | |
latest/candidate | 70 | 06 May 2024 | |
latest/edge | 70 | 06 May 2024 |
juju deploy hardware-observer --channel edge
20.04
Metrics
The details of the metrics exposed by Hardware Observer for PowerEdge RAID Controllers are as follows:
Metric Name | Description | Labels |
poweredgeraid_controllers | number of controllers | hostname |
poweredgeraid_virtual_drive | number of virtual drives | controller_id |
perccli_command_success | Indicates the if command is successful or not | controller_id |
perccli_command_ctrl_success | Indicates the if command for each controller is successful or not | controller_id |
poweredgeraid_virtual_drive_info | Indicates the state of virtual drive | controller_id, device_group, virtual_drive_id, state, cache_policy |
poweredgeraid_physical_device_info | Shows the information about the physical device | controller_id, enclosure_id, slot_id, size, media_type, state |
Alerts
The details of the alerts that are provided by Hardware Observer for PowerEdge RAID Controllers are as follows:
Alert Rule Name | Description | Severity |
PerccliCommandFailed | Failed to run perccli or controller not available. | critical |
PowerEdgeRAIDControllerNotFound | PowerEdge RAID controller not found. | warning |
PowerEdgeRAIDControllerSuccess | PowerEdge RAID controller command not successful. | critical |
PowerEdgeRAIDVirtualDriveNotOptimal | PowerEdge RAID virtual drives are not in optimal state. | warning |
