Hardware Observer
22.04
20.04
18.04
| latest/stable | 762 | 08 Jan 2026 | |
| latest/stable | 761 | 08 Jan 2026 | |
| latest/stable | 760 | 08 Jan 2026 | |
| latest/stable | 759 | 08 Jan 2026 | |
| latest/stable | 758 | 08 Jan 2026 | |
| latest/stable | 757 | 08 Jan 2026 | |
| latest/stable | 756 | 08 Jan 2026 | |
| latest/stable | 755 | 08 Jan 2026 | |
| latest/stable | 754 | 08 Jan 2026 | |
| latest/stable | 753 | 08 Jan 2026 | |
| latest/stable | 752 | 08 Jan 2026 | |
| latest/stable | 751 | 08 Jan 2026 | |
| latest/stable | 15 | 17 Jan 2025 | |
| latest/candidate | 762 | 11 Dec 2025 | |
| latest/candidate | 761 | 11 Dec 2025 | |
| latest/candidate | 760 | 11 Dec 2025 | |
| latest/candidate | 759 | 11 Dec 2025 | |
| latest/candidate | 758 | 11 Dec 2025 | |
| latest/candidate | 757 | 11 Dec 2025 | |
| latest/candidate | 756 | 11 Dec 2025 | |
| latest/candidate | 755 | 11 Dec 2025 | |
| latest/candidate | 754 | 11 Dec 2025 | |
| latest/candidate | 753 | 11 Dec 2025 | |
| latest/candidate | 752 | 11 Dec 2025 | |
| latest/candidate | 751 | 11 Dec 2025 | |
| latest/candidate | 15 | 02 Jan 2025 | |
| latest/edge | 882 | 23 Mar 2026 | |
| latest/edge | 881 | 23 Mar 2026 | |
| latest/edge | 880 | 23 Mar 2026 | |
| latest/edge | 879 | 23 Mar 2026 | |
| latest/edge | 878 | 23 Mar 2026 | |
| latest/edge | 877 | 23 Mar 2026 | |
| latest/edge | 876 | 23 Mar 2026 | |
| latest/edge | 875 | 23 Mar 2026 | |
| latest/edge | 874 | 23 Mar 2026 | |
| latest/edge | 873 | 23 Mar 2026 | |
| latest/edge | 872 | 23 Mar 2026 | |
| latest/edge | 871 | 23 Mar 2026 | |
| latest/edge | 15 | 03 Nov 2023 |
juju deploy hardware-observer --channel edge
Metrics
The details of the metrics exposed by Hardware Observer for HPE Smart Array Controllers are as follows:
| Metric Name | Description | Labels |
| ssacli_command_success | Indicates if the command is successful or not | |
| ssacli_controllers | Total number of controllers | |
| ssacli_controller_info | Shows information about controller part | slot, part, status |
| ssacli_logical_drives | The number of logical drives in the slot | slot |
| ssacli_logical_drive_info | Shows information about logical drive | slot, drive_id, status |
| ssacli_physical_drives | The number of physical drives in the slot | slot |
| ssacli_physical_drive_info | Shows information about physical drive | slot, drive_id, status |
Alerts
The details of the alerts that are provided by Hardware Observer for HPE Smart Array Controllers are as follows:
| Alert Rule Name | Description | Severity |
| SsaCLICommandFailed | Failed to run ssacli. | critical |
| SsaCLIControllerNotFound | ssacli controller not found. | warning |
| SsaCLIControllerNotOK | ssacli controller status not Ok. | critical |
| SsaCLILogicalDriveNotOK | ssacli logical drive status not Ok. | critical |
| SsaCLIPhysicalDriveNotOK | ssacli physical drive status not Ok. | critical |
