Grafana Agent
| 0.44/stable | 824 | 07 Jul 2026 | |
| 0.44/stable | 831 | 07 Jul 2026 | |
| 0.44/stable | 816 | 07 Jul 2026 | |
| 0.44/stable | 828 | 07 Jul 2026 | |
| 0.44/stable | 829 | 07 Jul 2026 | |
| 0.44/stable | 833 | 07 Jul 2026 | |
| 0.44/stable | 832 | 07 Jul 2026 | |
| 0.44/stable | 827 | 07 Jul 2026 | |
| 0.44/stable | 830 | 07 Jul 2026 | |
| 0.44/stable | 825 | 07 Jul 2026 | |
| 0.44/stable | 826 | 07 Jul 2026 | |
| 0.44/candidate | 893 | 11 Aug 2026 | |
| 0.44/candidate | 895 | 11 Aug 2026 | |
| 0.44/candidate | 896 | 11 Aug 2026 | |
| 0.44/candidate | 897 | 11 Aug 2026 | |
| 0.44/candidate | 898 | 11 Aug 2026 | |
| 0.44/candidate | 878 | 07 Aug 2026 | |
| 0.44/candidate | 880 | 07 Aug 2026 | |
| 0.44/candidate | 875 | 07 Aug 2026 | |
| 0.44/candidate | 876 | 07 Aug 2026 | |
| 0.44/candidate | 872 | 06 Aug 2026 | |
| 0.44/candidate | 825 | 07 Jul 2026 | |
| 0.44/beta | 893 | 11 Aug 2026 | |
| 0.44/beta | 895 | 11 Aug 2026 | |
| 0.44/beta | 896 | 11 Aug 2026 | |
| 0.44/beta | 897 | 11 Aug 2026 | |
| 0.44/beta | 898 | 11 Aug 2026 | |
| 0.44/beta | 878 | 07 Aug 2026 | |
| 0.44/beta | 880 | 07 Aug 2026 | |
| 0.44/beta | 875 | 07 Aug 2026 | |
| 0.44/beta | 876 | 07 Aug 2026 | |
| 0.44/beta | 872 | 06 Aug 2026 | |
| 0.44/beta | 825 | 07 Jul 2026 | |
| 0.44/edge | 898 | 10 Aug 2026 | |
| 0.44/edge | 897 | 10 Aug 2026 | |
| 0.44/edge | 896 | 10 Aug 2026 | |
| 0.44/edge | 895 | 10 Aug 2026 | |
| 0.44/edge | 893 | 10 Aug 2026 | |
| 0.44/edge | 880 | 06 Aug 2026 | |
| 0.44/edge | 878 | 06 Aug 2026 | |
| 0.44/edge | 876 | 06 Aug 2026 | |
| 0.44/edge | 875 | 06 Aug 2026 | |
| 0.44/edge | 872 | 05 Aug 2026 | |
| 0.44/edge | 825 | 07 Jul 2026 | |
| dev/edge | 960 | 15 Sep 2026 | |
| dev/edge | 959 | 15 Sep 2026 | |
| dev/edge | 958 | 15 Sep 2026 | |
| dev/edge | 957 | 11 Sep 2026 | |
| dev/edge | 956 | 11 Sep 2026 | |
| dev/edge | 955 | 11 Sep 2026 | |
| dev/edge | 954 | 11 Sep 2026 | |
| dev/edge | 953 | 11 Sep 2026 | |
| dev/edge | 936 | 27 Aug 2026 | |
| dev/edge | 929 | 27 Aug 2026 | |
| dev/edge | 925 | 26 Aug 2026 | |
| 2/stable | 851 | 07 Jul 2026 | |
| 2/stable | 846 | 07 Jul 2026 | |
| 2/stable | 850 | 07 Jul 2026 | |
| 2/stable | 849 | 07 Jul 2026 | |
| 2/stable | 848 | 07 Jul 2026 | |
| 2/stable | 847 | 07 Jul 2026 | |
| 2/candidate | 851 | 18 Jun 2026 | |
| 2/candidate | 846 | 18 Jun 2026 | |
| 2/candidate | 850 | 18 Jun 2026 | |
| 2/candidate | 849 | 18 Jun 2026 | |
| 2/candidate | 848 | 18 Jun 2026 | |
| 2/candidate | 847 | 18 Jun 2026 | |
| 2/beta | 851 | 18 Jun 2026 | |
| 2/beta | 846 | 18 Jun 2026 | |
| 2/beta | 850 | 18 Jun 2026 | |
| 2/beta | 849 | 18 Jun 2026 | |
| 2/beta | 848 | 18 Jun 2026 | |
| 2/beta | 847 | 18 Jun 2026 | |
| 2/edge | 851 | 17 Jun 2026 | |
| 2/edge | 850 | 17 Jun 2026 | |
| 2/edge | 849 | 17 Jun 2026 | |
| 2/edge | 848 | 17 Jun 2026 | |
| 2/edge | 847 | 17 Jun 2026 | |
| 2/edge | 846 | 17 Jun 2026 | |
| 1/stable | 606 | 18 Sep 2025 | |
| 1/stable | 605 | 18 Sep 2025 | |
| 1/stable | 607 | 18 Sep 2025 | |
| 1/stable | 603 | 18 Sep 2025 | |
| 1/stable | 604 | 18 Sep 2025 | |
| 1/stable | 602 | 18 Sep 2025 | |
| 1/candidate | 606 | 09 Sep 2025 | |
| 1/candidate | 605 | 09 Sep 2025 | |
| 1/candidate | 607 | 09 Sep 2025 | |
| 1/candidate | 603 | 09 Sep 2025 | |
| 1/candidate | 604 | 09 Sep 2025 | |
| 1/candidate | 602 | 09 Sep 2025 | |
| 1/beta | 606 | 02 Sep 2025 | |
| 1/beta | 605 | 02 Sep 2025 | |
| 1/beta | 607 | 02 Sep 2025 | |
| 1/beta | 603 | 02 Sep 2025 | |
| 1/beta | 604 | 02 Sep 2025 | |
| 1/beta | 602 | 02 Sep 2025 | |
| 1/edge | 607 | 20 Aug 2025 | |
| 1/edge | 606 | 20 Aug 2025 | |
| 1/edge | 605 | 20 Aug 2025 | |
| 1/edge | 604 | 20 Aug 2025 | |
| 1/edge | 603 | 20 Aug 2025 | |
| 1/edge | 602 | 20 Aug 2025 |
juju deploy grafana-agent --channel 0.44/edge
Sometimes applications are instrumented with more metrics than we want to afford, from a resources perspective. In such cases we can choose to selectively drop some metrics before they are ingested.
Discover high-cardinality metrics
Prometheus’s /tsdb-status endpoint is quite handy for discovering high cardinality metrics you may want to drop prior to ingestion.
In this guide, we will show how to drop all the go_gc_* metrics. To check how many go_gc_* metrics you currently have, run the following query:
count by (__name__) ({__name__=~"go_gc_.+"})
Means for dropping metrics
Metrics can be dropped by using the drop action in several different places:
- Under
<scrape_config>section (<metric_relabel_configs>subsection). For example: all the self-monitoring scrape jobs that e.g. COS Lite has in place. - Under
<remote_write>section (<write_relabel_configs>subsection). For example: prometheus can be told to drop metrics before pushing them to another prometheus over remote-write API. This use case is not addressed in this guide.
Drop metrics via metric name in scrape config
Charms that integrate with prometheus or grafana agent, provide a “scrape config” to MetricsEndpointProvider (imported from charms.prometheus_k8s.v0.prometheus_scrape).
Let’s take for example the alertmanager self-metrics that prometheus scrapes. If we do not want prometheus or grafana agent to ingest any go_gc_* metrics from alertmanager, then we need to adjust the scrape job specified in the alertmanager charm:
diff --git a/src/charm.py b/src/charm.py
index fa3678c..f0e943b 100755
--- a/src/charm.py
+++ b/src/charm.py
@@ -250,6 +250,13 @@ class AlertmanagerCharm(CharmBase):
"scheme": metrics_endpoint.scheme,
"metrics_path": metrics_path,
"static_configs": [{"targets": [target]}],
+ "metric_relabel_configs": [
+ "source_labels": ["__name__"],
+ "regex": "go_gc_.+",
+ "action": "drop",
return [config]
Drop metrics via the scrape-config charm
In a typical scrape-config deployment such as:
graph LR
some-external-target --- scrape-target --- scrape-config --- prometheus
We can specify the drop action via a config option for the scrape-config charm:
$ juju config sc metric_relabel_configs="$(cat <<EOF
- source_labels: ["__name__"]
regex: "go_gc_.+"
action: "drop"
EOF
References
- Official docs:
<relabel_config> - Dropping metrics at scrape time with Prometheus (robustperception, 2015)
- How relabeling in Prometheus works (grafana.com, 2022)
- How to drop and delete metrics in Prometheus (gh:tanmay-bhat, 2022)
- Playgrounds:
