0.40/stable 233 07 Jul 2026
Ubuntu 24.04
0.40/stable 232 07 Jul 2026
Ubuntu 24.04
0.40/candidate 243 07 Aug 2026
Ubuntu 24.04
0.40/candidate 242 07 Aug 2026
Ubuntu 24.04
0.40/beta 243 07 Aug 2026
Ubuntu 24.04
0.40/beta 242 07 Aug 2026
Ubuntu 24.04
0.40/edge 243 06 Aug 2026
Ubuntu 24.04
0.40/edge 242 06 Aug 2026
Ubuntu 24.04
dev/edge 263 15 Oct 2026
Ubuntu 24.04
dev/edge 262 15 Oct 2026
Ubuntu 24.04
2/stable 211 16 Mar 2026
Ubuntu 24.04
2/stable 210 16 Mar 2026
Ubuntu 24.04
2/candidate 221 18 Jun 2026
Ubuntu 24.04
2/candidate 220 18 Jun 2026
Ubuntu 24.04
2/beta 221 18 Jun 2026
Ubuntu 24.04
2/beta 220 18 Jun 2026
Ubuntu 24.04
2/edge 221 17 Jun 2026
Ubuntu 24.04
2/edge 220 17 Jun 2026
Ubuntu 24.04
1/stable 163 18 Sep 2025
1/stable 164 18 Sep 2025
1/candidate 168 07 Apr 2026
1/candidate 167 07 Apr 2026
1/beta 168 31 Mar 2026
1/beta 167 31 Mar 2026
1/edge 168 25 Sep 2025
1/edge 167 25 Sep 2025
juju deploy grafana-agent-k8s --channel dev/edge
Sometimes applications are instrumented with more metrics than we want to afford, from a resources perspective. In such cases we can choose to selectively drop some metrics before they are ingested.
Discover high-cardinality metrics
Prometheus’s /tsdb-status endpoint is quite handy for discovering high cardinality metrics you may want to drop prior to ingestion.
In this guide, we will show how to drop all the go_gc_* metrics. To check how many go_gc_* metrics you currently have, run the following query:
count by (__name__) ({__name__=~"go_gc_.+"})
Means for dropping metrics
Metrics can be dropped by using the drop action in several different places:
  • Under <scrape_config> section (<metric_relabel_configs> subsection). For example: all the self-monitoring scrape jobs that e.g. COS Lite has in place.
  • Under <remote_write> section (<write_relabel_configs> subsection). For example: prometheus can be told to drop metrics before pushing them to another prometheus over remote-write API. This use case is not addressed in this guide.
Drop metrics via metric name in scrape config
Charms that integrate with prometheus or grafana agent, provide a “scrape config” to MetricsEndpointProvider (imported from charms.prometheus_k8s.v0.prometheus_scrape).
Let’s take for example the alertmanager self-metrics that prometheus scrapes. If we do not want prometheus or grafana agent to ingest any go_gc_* metrics from alertmanager, then we need to adjust the scrape job specified in the alertmanager charm:
diff --git a/src/charm.py b/src/charm.py
index fa3678c..f0e943b 100755
--- a/src/charm.py
+++ b/src/charm.py
@@ -250,6 +250,13 @@ class AlertmanagerCharm(CharmBase):
             "scheme": metrics_endpoint.scheme,
             "metrics_path": metrics_path,
             "static_configs": [{"targets": [target]}],
+            "metric_relabel_configs": [
+                    "source_labels": ["__name__"],
+                    "regex": "go_gc_.+",
+                    "action": "drop",
         return [config]
Drop metrics via the scrape-config charm
In a typical scrape-config deployment such as:
graph LR
some-external-target --- scrape-target --- scrape-config --- prometheus
We can specify the drop action via a config option for the scrape-config charm:
$ juju config sc metric_relabel_configs="$(cat <<EOF
- source_labels: ["__name__"]
  regex: "go_gc_.+"
  action: "drop"
EOF
References
