GitHub runner
22.04
20.04
| latest/stable | 697 | 30 Jun 2026 | |
| latest/stable | 4 | 02 Jun 2026 | |
| latest/stable | 327 | 02 Jun 2026 | |
| latest/stable | 696 | 02 Jun 2026 | |
| latest/beta | 697 | 30 Jun 2026 | |
| latest/edge | 706 | 25 Aug 2026 | |
| latest/edge | 705 | 25 Aug 2026 | |
How to add custom labels
This charm supports adding custom labels to the runners.
By using juju config to change the
charm configuration labels, additional
custom labels can be attached to the self-hosted runners.
juju config <APP_NAME> labels=<COMMA_SEPARATED_LABELS>
Examples of a COMMA_SEPARATED_LABELS value include “large,gpu” and “small,arm64”.
Accepted values are alphanumeric values with underscores (_); whitespaces before and after the the
word will be automatically trimmed.
