GitHub runner
| latest/stable | 461 | 10 Dec 2025 | |
| latest/stable | 323 | 27 Jan 2025 | |
| latest/stable | 1 | 09 Feb 2022 | |
| latest/beta | 470 | Today | |
| latest/edge | 470 | Yesterday | |
20.04
How to change GitHub personal access token
This charm supports changing the GitHub personal access token (PAT) used.
Changing the token
Create a new GitHub Personal Access Token.
An example classic token scope for repository use:
repo
For managing token scopes (fine-grained token), refer to the token scopes Reference page.
By using juju config to change the charm configuration token the charm unregisters and removes the old self-hosted runners and instantiates new ones.
juju config <APP_NAME> token=<TOKEN>
