GitHub runner
- By Canonical IS DevOps
latest/stable | 161 | 29 Apr 2024 | |
latest/beta | 177 | 29 Apr 2024 | |
latest/edge | 177 | 25 Apr 2024 |
How to run on LXD cloud
This machine charm needs to run on virtual machines with nested virtualization enabled.
By default, juju machines on LXD are containers.
To run this charm on LXD, add virt-type=virtual-machine
to the constraints during deployment:
juju deploy github-runner --constraints="cores=2 mem=16G virt-type=virtual-machine" --config token=<TOKEN> --config path=<OWNER/REPO>
This constraint ensures the juju machine hosting the charm is a LXD virtual machine. See Managing resource usage for recommendation on cores
and mem
constraint.
