latest/stable 229 07 Jan 2026
Ubuntu 20.04
latest/edge 252 08 Apr 2026
Ubuntu 22.04 Ubuntu 20.04
latest/edge 249 07 Apr 2026
juju deploy discourse-k8s --channel edge
External access required by the Charm
Depending on the configuration of the charm, the following external accesses are needed:
  • Access to the PostgreSQL database (mandatory).
  • Access to the S3 server is S3 is configured in the charm.
  • Access to GitHub to download Promtail if the logging interface is used in the charm.
If the option “external system avatars enabled” is enabled in the admin, access to https://avatars.discourse.org is necessary.
Besides that, other services, like link previews and installing themes from a git repository may need access to external sites to work, so allowing internet access to the Discourse instance is recommended. In restricted environments, the model-config options juju-http-proxy, juju-https-proxy and juju-no-proxy can be used to set up a proxy for Discourse, see Using proxies with Charmed Kubernetes for more information.
Help improve this document in the forum (guidelines). Last updated 3 months ago.
