0.31/stable 230 06 Jul 2026
Ubuntu 26.04
0.31/candidate 255 13 Oct 2026
Ubuntu 26.04
0.31/beta 255 13 Oct 2026
Ubuntu 26.04
0.31/edge 255 12 Oct 2026
Ubuntu 26.04
dev/edge 259 15 Oct 2026
Ubuntu 26.04
2/stable 231 07 Jul 2026
Ubuntu 24.04
2/candidate 231 04 Jul 2026
Ubuntu 24.04
2/beta 231 04 Jul 2026
Ubuntu 24.04
2/edge 231 03 Jul 2026
Ubuntu 24.04
1/stable 180 18 Sep 2025
Ubuntu 20.04
1/candidate 180 09 Sep 2025
Ubuntu 20.04
1/beta 180 02 Sep 2025
Ubuntu 20.04
1/edge 180 01 Sep 2025
Ubuntu 20.04
0.34/stable 250 12 Oct 2026
Ubuntu 26.04
0.34/candidate 250 02 Oct 2026
Ubuntu 26.04
0.34/beta 250 02 Oct 2026
Ubuntu 26.04
0.34/edge 250 01 Oct 2026
Ubuntu 26.04
juju deploy alertmanager-k8s --channel 2/edge
        labels:
          model: "some-juju-model"
Dashboards
Metrics
Alert rules
For built-in alert rules,
  • Alert exprs are qualified with topology labels. This way, built-in alerts fire only for the particular charm they originated from.
  • Alert labels are enriched with topology labels. This is meant for convenient reading of a rendered alert when presented to an on-caller. The labels would also be visible in the alert’s rendered expr, but alert labels are more convenient to read.
  • Alert rules are NOT enriched with the unit label. This is because we wouldn’t want to replicated all rules per unit. Unit information is included in metric and log labels. Since alert rules are forwarded to prometheus/loki per related app, not unit, having multiple units does not result in prometheus having duplicated alerts per unit. If an alert was qualified with a unit (which one?), we wouldn’t get alerts from any other units.
  • Alert rules descriptions can use a {{ $labels.juju_unit }} macro in the alert’s annotations, which will be replaced with the unit name for better readability.
Logs
Traces
Additional notes
  • In the future, the grafana-agent charm may start exposing metrics and logs generated by its own workload, and those would be enriched by juju topology labels.
  • In the future, the cos-configuration charm may start exposing metrics and logs generated by its own workload, git-sync, and those would be enriched by juju topology labels.
  • In the future (2025) grafana-agent will be replaced by otlp-collector. The general data flow should remain unchanged.
Help improve this document in the forum (guidelines). Last updated 1 year, 11 months ago.
