wordpress-k8s
WordPress
  • Canonical IS DevOps
latest/stable 127 11 Mar 2025
Ubuntu 22.04 Ubuntu 20.04
latest/stable 13 06 Mar 2023
latest/edge 139 03 Apr 2025
latest/edge 15 30 Mar 2023
juju deploy wordpress-k8s --channel edge
How to configure initial settings
NOTE This only works when setting up WordPress initially, before the database integration setup. Changing the value afterwards has no effect.
By providing configuration value for initial_settings at deployment, you can tweak a few WordPress settings. For detailed information on configurable parameters, please refer to the reference guide.
WORDPRESS_SETTINGS=$(cat << EOF
user_name: admin
admin_email: admin@testing.com
admin_password: <strong-password>
EOF
juju deploy wordpress-k8s --config initial_settings=$WORDPRESS_SETTINGS
You can verify your initial WordPress settings by navigating to ​​the general settings page in WordPress (http://<wordpress-unit-ip>/wp-admin/options-general.php).
You can also pass in the wordpress-k8s configuration.yaml file with the parameters above. See how to pass in a configuration file in the Juju documentation.
