Temporary performance degradation
We are currently experiencing service degradation and working on resolving this. Thank you for your patience and understanding.
Vault Operator
latest/edge 31 22 Feb 2024
juju deploy vault-dev --channel edge
Scale
The Vault charm uses the raft backend to scale. This guide walks you through scaling Vault.
Pre-requisites:
  • Vault is initialised and unseal
  • The Vault charm is authorised
1. Validate that Vault is an active state
Run juju status:
Model  Controller           Cloud/Region         Version  SLA          Timestamp
demo   localhost-localhost  localhost/localhost  3.4.0    unsupported  12:11:19-04:00
App    Version  Status  Scale  Charm  Channel    Rev  Exposed  Message
vault           active      1  vault  1.15/beta  257  no
Unit      Workload  Agent  Machine  Public address  Ports  Message
vault/0*  active    idle   0        10.191.126.116
Machine  State    Address         Inst id        Base          AZ  Message
0        started  10.191.126.116  juju-b8368f-0  ubuntu@22.04      Running
2. Scale Vault to 3 units
Add 2 more units:
juju add-unit vault -n 2
The new units will be sealed:
demo   localhost-localhost  localhost/localhost  3.4.0    unsupported  12:19:14-04:00
vault           blocked      3  vault  1.15/beta  257  no       Waiting for Vault to be unsealed
vault/1   blocked   idle   1        10.191.126.151         Waiting for Vault to be unsealed
vault/2   blocked   idle   2        10.191.126.90          Waiting for Vault to be unsealed
1        started  10.191.126.151  juju-b8368f-1  ubuntu@22.04      Running
2        started  10.191.126.90   juju-b8368f-2  ubuntu@22.04      Running
Set the VAULT_ADDR variable to the vault/1 unit:
export VAULT_ADDR=https://$(juju status vault/1 --format=yaml | awk '/public-address/ { print $2 }'):8200; echo $VAULT_ADDR
Unseal the the vault/1 unit using the same unseal keys as received during the initialization of the Vault leader:
vault operator unseal EJoB62t286mjUpSQYZg3mOla3lz/bbElVL5OLnj+rpE=
And complete the same operations for the vault/2 unit:
export VAULT_ADDR=https://$(juju status vault/2 --format=yaml | awk '/public-address/ { print $2 }'):8200; echo $VAULT_ADDR
3. Validate that all units are part of the cluster
All units should go to the Active/Idle Juju status:
$ juju status
demo   localhost-localhost  localhost/localhost  3.4.0    unsupported  12:24:32-04:00
vault           active      3  vault  1.15/beta  257  no
vault/1   active    idle   1        10.191.126.151
vault/2   active    idle   2        10.191.126.90
And they should all be part of the raft cluster:
$ vault operator raft list-peers
Node            Address                State       Voter
demo-vault/0    10.191.126.116:8201    leader      true
demo-vault/1    10.191.126.151:8201    follower    true
demo-vault/2    10.191.126.90:8201     follower    true
