Superset Operator
| latest/stable | 39 | 30 Apr 2025 | |
| latest/edge | 69 | 24 Jul 2026 | |
| 6/stable | 68 | 10 Jul 2026 | |
| 6/edge | 68 | 10 Jul 2026 | |
| 5/stable | 48 | 26 Nov 2025 | |
| 5/edge | 48 | 21 Nov 2025 |
juju deploy superset-k8s --channel 6/edge
This final step of the tutorial focuses on removing Juju applications, models and controller to completely cleanup the deployment.
Remove the controller
If you’re done with testing and would like to free up resources on your machine, run the following command:
juju destroy-controller -y --destroy-all-models --destroy-storage superset-controller
When you remove the models, all the data in PostgreSQL and any other applications inside the model are lost.
Next steps
- Integrate Canonical Observability Stack.
- Implement security features.
- Optimise deployment performance.
- Learn which feature flags are supported.
