Charmed Spark K8s
  • Canonical | bundle
Channel Revision Published
latest/edge 4 06 Aug 2024
3.4/edge 4 06 Aug 2024
Interacting with Apache Spark using Interactive Shell
Apache Spark comes with an interactive shell that provides a simple way to learn the API. It is available in either Scala or Python. In this section, we’re going to play around a bit with Spark’s shell to interact directly with the Apache Spark cluster.
PySpark Shell
Charmed Apache Spark comes with a built-in Python shell where we can execute commands interactively against the Apache Spark cluster using the Python programming language.
PySpark shell can be launched with the spark-client snap like this:
spark-client.pyspark \
  --username spark --namespace spark
Once the shell is open and ready, you should see a prompt similar to the following:
Welcome to
      ____              __
     / __/__  ___ _____/ /__
    _\ \/ _ \/ _ `/ __/  '_/
   /__ / .__/\_,_/_/ /_/\_\   version 3.4.1
      /_/
Using Python version 3.10.12 (main, Jun 11 2023 05:26:28)
Spark context Web UI available at http://172.31.29.134:4040
Spark context available as 'sc' (master = k8s://https://172.31.29.134:16443, app id = spark-b364a0a9a2cb41f3a713c62b900fbd82).
SparkSession available as 'spark'.
When you open the PySpark shell, Charmed Apache Spark spawns a couple of executor pods in the background to process commands. You can see them by fetching the list of pods in the spark namespace in a separate shell.
kubectl get pods -n spark
You should see output lines similar to the following:
pysparkshell-xxxxxxxxxxxxxxxx-exec-1              1/1     Running            0          xs
pysparkshell-xxxxxxxxxxxxxxxx-exec-2              1/1     Running            0          xs
As you can see, PySpark spawned two executor pods within the spark namespace. This is the namespace that we provided as a value to the --namespace argument when launching pyspark. It’s in these executor pods that data is cached and the computation will be executed, therefore creating a computational architecture that can horizontally scale to large datasets (“big data”).
On the other hand, the PySpark shell started by the spark-client snap will act as a driver, controlling and orchestrating the operations of the executors. More information about the Apache Spark architecture can be found in the Apache Spark documentation.
One good thing about the shell is that the Apache Spark Context and session are already pre-loaded onto the shell and can be easily accessed with variables sc and spark respectively. You can even see this printed in the logs above, where upon initialization, the PySpark shell says Spark context available as 'sc' and SparkSession available as 'spark'. This shell is just like a regular Python shell, with Apache Spark Context loaded on top of it.
To start, you can print ‘hello, world!’ just like you’d do in a Python shell.
>>> print('hello, world!')
hello, world!
Let’s try a simple example of counting the number of vowel characters in a string. The following is the string that we are going to use:
lines = """Canonical's Charmed Data Platform solution for Apache Spark runs Spark jobs on your Kubernetes cluster.
You can get started right away with MicroK8s - the mightiest tiny Kubernetes distro around!
The spark-client snap simplifies the setup process to get you running Spark jobs against your Kubernetes cluster.
Spark on Kubernetes is a complex environment with many moving parts.
Sometimes, small mistakes can take a lot of time to debug and figure out.
The following is a function that returns the number of vowel characters in the string:
def count_vowels(text: str) -> int:
  count = 0
  for char in text:
    if char.lower() in "aeiou":
      count += 1
  return count
To test this function, the string lines can now be passed into it and the number of vowels is printed to the console as follows:
>>> count_vowels(lines)
134
Since Apache Spark is a distributed processing framework, we can split up this task and parallelize it over multiple executor pods. This parallelization can be done as simply as:
>>> from operator import add
>>> spark.sparkContext.parallelize(lines.splitlines(), 2).map(count_vowels).reduce(add)
134
Here, we split the data into two executors (passed as an argument to parallelize function), generating a distributed data structure, e.g. RDD[str], where each line is stored in one of the (possibly many) executors. The number of vowels in each line is then computed, line by line, with the map function, and then the numbers are aggregated and added up to calculate the total number of occurrences of vowel characters in the entire dataset. This kind of parallelization of tasks is particularly useful in processing very large data sets which helps to reduce the processing time significantly, and it is generally referred to as the MapReduce pattern.
To exit from the PySpark shell, you can simply run exit() or press Ctrl + Z key combination.
Scala Shell
Apache Spark comes with a built-in interactive Scala shell as well. Enter the following command to enter an interactive Scala shell:
spark-client.spark-shell --username spark --namespace spark --num-executors 4
Notice how we can specify the number of executors when initializing the Apache Spark Shell (which by default would be 2). Once the shell is open and ready, you should see a prompt similar to the following:
Welcome to
      ____              __
   /___/ .__/\_,_/_/ /_/\_\   version 3.4.1
      /_/
Using Scala version 2.12.17 (OpenJDK 64-Bit Server VM, Java 11.0.20.1)
Type in expressions to have them evaluated.
Type :help for more information.
scala>
Just as in the PySpark shell, the Apache Spark Context and Apache Spark session are readily available in the shell as sc and spark respectively. Moreover, new executor pods are created in spark namespace in order to execute the commands, just like with the PySpark shell.
The example of counting the vowel characters can be equivalently run in Scala with the following lines:
val lines = """Canonical's Charmed Data Platform solution for Apache Spark runs Spark jobs on your Kubernetes cluster.
The spark-client snap simplifies the setup to run Spark jobs against your Kubernetes cluster.
def countVowels(text: String): Int = {
  text.toLowerCase.count("aeiou".contains(_))
sc.parallelize(lines.split("\n"), 2).map(countVowels).reduce(_ + _)
To exit from the Scala shell, simply press Ctrl + C key combination.
Interactive shells are a great way to experiment and learn the basics of Apache Spark. For a more advanced use case, jobs can be submitted to the Apache Spark cluster as scripts using spark-submit. That’s what we will do in the next section.
Help improve this document in the forum (guidelines). Last updated 3 months ago.
