Charmed Spark K8s
- Canonical | bundle
juju deploy spark-k8s-bundle --channel edge
Manage encryption and passwords
The Charmed Apache Kyuubi K8s charm supports TLS encryption for data in transit and uses Juju secrets to securely store and manage passwords.
This guide shows how to enable TLS encryption, manage encryption keys, retrieve certificate chain, and manage passwords.
Manage encryption
The Charmed Apache Kyuubi K8s charm implements the Requirer side of the tls-certificates/v4 charm relation.
Enable encryption
To enable encryption, you should first deploy a TLS certificates Provider charm that implements the Provider side of the relation and then, integrate the charms.
For this guide, we will use self-signed certificates, but similar approach can be employed for other TLS certificate providers.
Avoid using self-signed TLS certificates in production environments.
Please refer to the X.509 certificates post for an overview of the TLS certificates Providers charms and some guidance on how to choose the right charm for your use case.
Deploy certificate provider charm, for example:
juju deploy self-signed-certificates --channel=1/stable
Add necessary configuration parameters:
juju config self-signed-certificates ca-common-name="Test CA"
Integrate the certificate provider charm with Charmed Apache Kyuubi:
juju integrate <tls-certificates> kyuubi-k8s
where <tls-certificates> is the name of the TLS certificate provider charm deployed.
Disable encryption
To disable TLS encryption, remove the relation:
juju remove-relation <tls-certificates> kyuubi-k8s
Manage keys
Updates to private keys for certificate signing requests (CSR) can be made via the tls-client-private-key configuration option.
If this configuration option is not set, the charm will generate a new private key and use it instead.
To generate a shared internal key:
openssl genrsa -out internal-key.pem 3072
Create a new Juju secret using the content of the shared key file:
juju add-secret kyuubi-tls-secret private-key#file=internal-key.pem
The above command returns a secret id, for example: secret:d1seounmp25c76bq4ha0.
To grant access for an application to the secret, run juju grant-secret command, for example:
juju grant-secret kyuubi-tls-secret kyuubi-k8s
Finally, configure the application to use the secret using the secret id from before:
juju config kyuubi-k8s tls-client-private-key=secret:d1seounmp25c76bq4ha0
To rotate a private key, update the associated secret:
juju update-secret kyuubi-tls-secret private-key#file=new-internal-key.pem
See also:
juju update-secretcommand reference.
Retrieve the certificate chain
To retrieve the certificate in use, use the data-integrator charm:
juju run data-integrator/0 get-credentials | yq ".kyuubi.tls-ca"
Manage passwords
Charmed Apache Kyuubi K8s uses Juju secrets to manage passwords.
See also: Juju | How to manage secrets
Create a password
Create a secret in Juju containing one or more user passwords:
juju add-secret <secret_name> admin=<password>
The above outputs a secret URI, which you need for configuring system-users configuration parameter.
Without a valid secret granted to the application, the admin user uses an automatically created password.
To grant the secret to the kyuubi-k8s charm:
juju grant-secret <secret_name> kyuubi-k8s
Configure the system-users
To set the system-users configuration option to the secret URI:
juju config charm-app system-users=<secret_URI>
When the system-users configuration option is set, the charm:
- Uses the specified secret instead of the auto generated one.
- Updates the passwords of the internal
system-usersin its user database.
If the configuration option is not specified, the charm automatically generates passwords for the internal system-users and store them in a secret.
Retrieve a password
To retrieve the password of an internal system-user, run the juju show-secret command with the respective secret URI.
Update a password
To update a password, update the associated secret:
juju update-secret <secret_name> admin=<new_password>
