Charmed Spark K8s
Channel Revision Published
latest/edge 4 06 Aug 2024
3.4/edge 4 06 Aug 2024
juju deploy spark-k8s-bundle --channel edge
3. Data stream processing
Apache Spark comes with a built-in support for streaming workloads via Apache Spark Streaming. Charmed Apache Spark takes it a step further by making it easy to integrate with Apache Kafka using Juju.
Apache Kafka is a distributed event-store with a producer/consumer API, designed to achieve massive throughput with clustering for horizontal scalability and high availability. For more information about Apache Kafka, see the Apache Kafka project page, and for Apache Spark Streaming, see the Apache Spark project documentation.
In this step of the tutorial, we are going to generate some data, push it to Apache Kafka, and then consume the stream of data using Apache Spark, making an aggregation. We are going to use juju to deploy an Apache Kafka cluster as well as a simple test application which will generate and push events to Apache Kafka. We will then show how to set up a Spark job to continuously consume those events from Apache Kafka and calculate some statistics.
Setup
First of all, let’s start by creating a fresh juju model to be used as an experimental workspace for this project:
juju add-model spark-streaming
When you add a Juju model, a Kubernetes namespace of the same name is created automatically. You can verify that by running kubectl get namespaces - you should see a namespace called spark-streaming.
The service account spark that we created in the earlier section is in the spark namespace. Let’s create a similar service account but now in the spark-streaming namespace. We can copy the existing config options from the old service account into the new service account.
Get config from the old service account in the spark namespace and store it in a file:
spark-client.service-account-registry get-config \
  --username spark --namespace spark > properties.conf
Create a new service account with the same name by in the spark-streaming namespace and load configurations from the file:
spark-client.service-account-registry create \
  --username spark --namespace spark-streaming \
  --properties-file properties.conf
Now, let’s create a minimal Apache Kafka and Apache ZooKeeper setup. This can be done quickly and easily using the zookeeper-k8s and kafka-k8s charms. Although this setup is not highly available, using single instances for both should be enough to understand the underlying concepts.
juju deploy zookeeper-k8s --trust
juju deploy kafka-k8s --trust
juju integrate kafka-k8s zookeeper-k8s
For more details on the Charmed Apache Kafka K8s deployment process, see the How to deploy guide.
Once installed, let’s see the current status of the Juju model with the following command:
juju status --watch 1s
Once all the charms have been deployed and integrated (you may need to wait some time), output similar to the following should appear:
Model            Controller      Cloud/Region        Version  SLA          Timestamp
spark-streaming  spark-tutorial  microk8s/localhost  3.1.7    unsupported  10:13:55Z
App            Version  Status  Scale  Charm          Channel  Rev  Address         Exposed  Message
kafka-k8s               active      1  kafka-k8s      3/edge    47  10.152.183.242  no
zookeeper-k8s           active      1  zookeeper-k8s  3/edge    42  10.152.183.87   no
Unit              Workload  Agent  Address      Ports  Message
kafka-k8s/0*      active    idle   10.1.29.184
zookeeper-k8s/0*  active    idle   10.1.29.182
As you can see, both Apache Kafka and Apache ZooKeeper charms are in the “active” status.
If you see kafka-k8s unit with the zookeeper credentials not created yet message and waiting - just wait a few more minutes (up to 5-10) for the charms to synchronize and share credentials with each other.
Generating data stream
For us to experiment with the streaming feature, we need some sample streaming data to be generated in Apache Kafka continuously in real-time. For that, we can use the kafka-test-app charm to produce events.
Let’s deploy this charm with 3 units, and integrate it with kafka-k8s so that it is able to write messages to Apache Kafka.
juju deploy kafka-test-app -n 3 --config role=producer --config topic_name=spark-streaming-store --config num_messages=100000
juju integrate kafka-test-app kafka-k8s
Once the integration is complete, juju status should display something similar to:
spark-streaming  spark-tutorial  microk8s/localhost  3.6.4    unsupported  10:17:32Z
kafka-k8s                active      1  kafka-k8s       3/stable      47  10.152.183.242   no
kafka-test-app           active      3  kafka-test-app  latest/stable  8  10.152.183.167   no       Topic spark-streaming-store enabled with process producer
zookeeper-k8s            active      1  zookeeper-k8s   3/stable      42  10.152.183.87    no
kafka-test-app/0   active    idle   10.1.29.185         Topic spark-streaming-store enabled with process producer
kafka-test-app/1   active    idle   10.1.29.186         Topic spark-streaming-store enabled with process producer
kafka-test-app/2*  active    idle   10.1.29.187         Topic spark-streaming-store enabled with process producer
Now messages will be generated and written to Apache Kafka periodically by kafka-test-app. However, to establish a connection and actually consume these messages from Apache Kafka, Apache Spark needs to authenticate with Apache Kafka using the credentials. For the retrieval of these credentials, we are going to use the data-integrator charm. Let’s deploy data-integrator and integrate it with kafka-k8s with the following commands:
juju deploy data-integrator --config extra-user-roles=consumer,admin --config topic-name=spark-streaming-store
juju integrate data-integrator kafka-k8s
Once this integration is complete, juju status should appear something similar to:
spark-streaming  spark-tutorial  microk8s/localhost  3.1.7    unsupported  10:22:14Z
data-integrator           active      1  data-integrator  edge      15  10.152.183.18   no
kafka-test-app            active      3  kafka-test-app   edge       8  10.152.183.167  no       Topic spark-streaming-store enabled with process producer
data-integrator/0*  active    idle   10.1.29.189
Now that data-integrator is deployed and integrated with kafka-k8s, we can get the credentials to connect to Apache Kafka by running the get-credentials action exposed by the data-integrator charm:
juju run data-integrator/0 get-credentials
The output generated by this command is similar to the following:
  - task 2 on unit-data-integrator-0
Waiting for task 2...
kafka:
  consumer-group-prefix: relation-10-
  data: '{"extra-user-roles": "consumer,admin", "requested-secrets": "[\"username\",
    \"password\", \"tls\", \"tls-ca\", \"uris\"]", "topic": "spark-streaming-store"}'
  endpoints: kafka-k8s-0.kafka-k8s-endpoints:9092
  password: oZZVg6diO1ao1uA8izYCw396PUwHkwVR
  tls: disabled
  topic: spark-streaming-store
  username: relation-10
  zookeeper-uris: zookeeper-k8s-0.zookeeper-k8s-endpoints:2181/kafka-k8s
ok: "True"
As you can see, the endpoint, username and password to be used to authenticate with Kafka are displayed next to “endpoints”, “username” and “password” respectively. It will help if we store the username and password as variables so that they can be used later in the tutorial. To do that, we can specify --format=json when running the get-credentials action, and then filter out username and password using jq:
export KAFKA_USERNAME=$(juju run data-integrator/0 get-credentials --format=json | jq -r '.["data-integrator/0"].results.kafka.username')
export KAFKA_PASSWORD=$(juju run data-integrator/0 get-credentials --format=json | jq -r '.["data-integrator/0"].results.kafka.password')
export KAFKA_ENDPOINT=$(juju run data-integrator/0 get-credentials --format=json | jq -r '.["data-integrator/0"].results.kafka.endpoints')
Let’s see the format of an event generated by kafka-test-app:
{"timestamp": 1707128717.277745, "_id": "339e0f352b4843bfa0d512b796019a92", "origin": "kafka-test-app-0 (10.1.29.185)", "content": "Message #121"}
As we can see, the value of the “origin” key is the name and the IP address of the unit producing the events.
Stream processing
Now we will write a Spark job in Python that counts the number of events grouped by the “origin” key in real-time.
Preparing a Python script
First, we will authenticate with Apache Kafka and load the events from the spark-streaming-store topic. This can be done using the spark.readStream function:
lines = spark.readStream \
        .format("kafka") \
        .option("kafka.bootstrap.servers", "kafka-k8s-0.kafka-k8s-endpoints:9092") \
        .option("kafka.sasl.mechanism", "SCRAM-SHA-512") \
        .option("kafka.security.protocol", "SASL_PLAINTEXT") \
        .option("kafka.sasl.jaas.config", f'org.apache.kafka.common.security.scram.ScramLoginModule required username="relation-9" password="g6c5gjg48IjTFld664ipkz8Khqb5FOG0";') \
        .option("subscribe", "spark-streaming-store") \
        .option("includeHeaders", "true") \
        .load()
Now, let’s create a user-defined function that fetches the value of the “origin” column from the event:
from pyspark.sql.functions import udf
from json import loads
get_origin = udf(lambda x: loads(x)["origin"])
Then let’s count the number of events grouped by the value of the “origin” key, which is returned by the get_origin function that we wrote above:
count = lines.withColumn(
            "origin",
            get_origin(col("value"))
          ).select("origin").groupBy("origin").count()
Finally, writing the result continuously to the console until the job is terminated can be done as follows:
query = w_count.writeStream.outputMode("complete").format("console").start()
query.awaitTermination()
Putting all of this together and enabling username, password, endpoint and topic to be passed as command line arguments, we get the following script:
import argparse
from pyspark.sql import SparkSession
from pyspark.sql.functions import udf, col
# Create a Spark Session
spark = SparkSession.builder.appName("SparkStreaming").getOrCreate()
# Read username, password and endpoint from command line arguments
parser = argparse.ArgumentParser()
parser.add_argument("--kafka-username", "-u",
                help="The username to authenticate to Kafka",
                required=True)
parser.add_argument("--kafka-password", "-p",
                help="The password to authenticate to Kafka",
                  required=True)
parser.add_argument("--kafka-endpoint", "-e",
                  help="The bootstrap server endpoint",
                    required=True)
parser.add_argument("--kafka-topic", "-t",
                  help="The Kafka topic to subscribe to",
                    required=True)
args = parser.parse_args()
username=args.kafka_username
password=args.kafka_password
endpoint=args.kafka_endpoint
topic=args.kafka_topic
# Authenticating with Kafka and reading the stream from the topic
        .format("kafka") \
        .option("kafka.bootstrap.servers", endpoint) \
        .option(
          f'org.apache.kafka.common.security.scram.ScramLoginModule required username="{username}" password="{password}";'
        ).option("subscribe", topic) \
        .load()
# User defined function that returns the origin of one particular event
# Group by origin of the event and count number of event for each origins
            "origin",
# Start writing the result to console
query = count.writeStream.outputMode("complete").format("console").start()
# Keep doing this until the job is terminated
Save the Python code above in a file named spark_streaming.py. Copy this file from the Host machine to the VM:
multipass transfer spark_streaming.py spark-tutorial-4:spark_streaming.py
Then, from the VM, copy it to the S3:
aws s3 cp spark_streaming.py s3://spark-tutorial/spark_streaming.py
Running the script
Once the file has been copied to S3, let’s submit a new job to our Apache Spark cluster using spark-submit. Please note that we need to specify a few extra packages to interact with Apache Kafka because they are not included by default in the Charmed Apache Spark image:
spark-client.spark-submit \
    --deploy-mode cluster \
    --packages org.apache.spark:spark-streaming-kafka-0-10_2.12:3.4.1,org.apache.spark:spark-sql-kafka-0-10_2.12:3.4.1 \
    s3a://spark-tutorial/spark_streaming.py \
        --kafka-endpoint $KAFKA_ENDPOINT \
        --kafka-username $KAFKA_USERNAME \
        --kafka-password $KAFKA_PASSWORD \
        --kafka-topic "spark-streaming-store"
The job submission should start a driver pod, which in turn will spawn executor pods. The executor pods will then transition to the “Running” state, and the streaming data will be processed continuously by them.
Check the results
We can view the status of the pods with the following command in a new terminal window:
watch -n1 "kubectl get pods -n spark-streaming | grep 'spark-streaming-.*-driver' "
The streaming output - directed to the console - is being written to the pod logs. To fetch the pod logs, we first need to know the name of the driver pod. Let’s find its name to then fetch the logs as:
pod_name=$(kubectl get pods -n spark-streaming | grep "spark-streaming-.*-driver" | tail -n 1 | cut -d' ' -f1)
kubectl logs -n spark-streaming -f $pod_name | grep "Batch: " -A 10 # filter out line starting with "Batch: " and next 10 lines after that line
The option -f will tail the pod logs until Ctrl + C keys are pressed. If you observe carefully, you can see that new logs are appended roughly every ten seconds, including our aggregated results calculation containing the number of events grouped by the origin, similar to the following:
2025-04-08T10:00:38.367Z [sparkd] Batch: 5
2025-04-08T10:00:38.367Z [sparkd] -------------------------------------------
2025-04-08T10:00:38.381Z [sparkd] +--------------------+-----+
2025-04-08T10:00:38.381Z [sparkd] |              origin|count|
2025-04-08T10:00:38.381Z [sparkd] |kafka-test-app-1 ...|   53|
2025-04-08T10:00:38.381Z [sparkd] |kafka-test-app-0 ...|   53|
2025-04-08T10:00:38.381Z [sparkd] |kafka-test-app-2 ...|   53|
At this point, we’ve successfully processed a data stream using the Charmed Apache Spark solution.
Clean up
Stop all running commands in all terminals by pressing Ctrl + C.
To free up the resources used by in this step of the tutorial, delete the spark-streaming model that we’ve used to deploy Apache Kafka and Apache ZooKeeper charms by running the following command in the VM:
juju destroy-model spark-streaming --release-storage
With that the data streaming part of this tutorial is complete.
Help improve this document in the forum (guidelines). Last updated 9 months ago.
