Charmed PostgreSQL K8s
- Canonical
14/edge | 555 | 04 Apr 2025 | |
14/edge | 554 | 04 Apr 2025 | |
16/edge | 552 | 02 Apr 2025 |
If you’re using juju 2.9
, check the juju 3.0
Release Notes.
Enable tracing
This guide contains the steps to enable tracing with Grafana Tempo for your PostgreSQL K8s application.
To summarize:
- Deploy the Tempo charms and their dependencies in a COS K8s environment
- Offer interfaces for cross-model integrations
- Consume and integrate cross-model integrations
- View PostgreSQL K8s traces on Grafana
This feature is available for Charmed PostgreSQL K8s revision 292+ only.
- Have deployed a Charmed PostgreSQL K8s application
- Have deployed a ‘cos-lite’ bundle from the
latest/edge
track in a Kubernetes environment
Deploy Tempo
Then, deploy the dependencies of Tempo following this tutorial. In particular, we would want to:
- Deploy the minio charm
- Deploy the s3 integrator charm
- Add a bucket in minio using a python script
- Configure s3 integrator with the minio credentials
Finally, deploy and integratre with Tempo HA in a monolithic setup.
Offer interfaces
Next, offer interfaces for cross-model integrations from the model where Charmed PostgreSQL K8s is deployed.
juju offer <tempo_coordinator_k8s_application_name>:tracing
Then, switch to the Charmed PostgreSQL K8s model, find the offers, and integrate (relate) with them:
juju switch <k8s_controller_name>:<postgresql_k8s_model_name>
Do not miss the “
” in the command above.
Below is a sample output where k8s
is the K8s controller name and cos
is the model where cos-lite
and tempo-k8s
are deployed:
Store URL Access Interfaces
k8s admin/cos.tempo admin tracing:tracing
juju consume k8s:admin/cos.tempo
Consume interfaces
First, deploy Grafana Agent K8s from the latest/edge
channel:
juju deploy grafana-agent-k8s --channel latest-edge
Then, integrate Grafana Agent K8s with the consumed interface from the previous section:
juju integrate grafana-agent-k8s:tracing tempo:tracing
Finally, integrate Charmed PostgreSQL K8s with Grafana Agent K8s:
juju integrate postgresql-k8s:tracing grafana-agent-k8s:tracing-provider
Wait until the model settles. The following is an example of the juju status --relations
on the Charmed PostgreSQL model:
database k8s microk8s/localhost 3.5.4 unsupported 16:52:21Z
SAAS Status Store URL
tempo active k8s admin/cos.tempo
grafana-agent-k8s 0.40.4 active 1 grafana-agent-k8s latest/edge 93 10.152.183.226 no grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
postgresql-k8s 14.13 active 1 postgresql-k8s 0 10.152.183.96 no
grafana-agent-k8s/0* active idle 10.1.241.195 grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
postgresql-k8s/0* active idle 10.1.241.197 Primary
grafana-agent-k8s:peers grafana-agent-k8s:peers grafana_agent_replica peer
grafana-agent-k8s:tracing-provider postgresql-k8s:tracing tracing regular
postgresql-k8s:database-peers postgresql-k8s:database-peers postgresql_peers peer
postgresql-k8s:restart postgresql-k8s:restart rolling_op peer
postgresql-k8s:upgrade postgresql-k8s:upgrade upgrade peer
tempo:tracing grafana-agent-k8s:tracing tracing regular
View traces
After this is complete, the Tempo traces will be accessible from Grafana under the Explore
section with tempo-k8s
as the data source. You will be able to select postgresql-k8s
as the Service Name
under the Search
tab to view traces belonging to Charmed PostgreSQL K8s.
Below is a screenshot demonstrating a Charmed PostgreSQL K8s trace:
Feel free to read through the Tempo HA documentation at your leisure to explore its deployment and its integrations.
