Charmed PostgreSQL K8s
- Canonical
14/edge | 557 | Today | |
14/edge | 556 | Today | |
16/edge | 552 | 02 Apr 2025 |
How to deploy
This page aims to provide an introduction to the PostgreSQL deployment process and lists all the related guides. It contains the following sections:
General deployment instructions
The basic requirements for deploying a charm are the Juju client and a Kubernetes cloud.
First, bootstrap the cloud controller and create a model:
juju bootstrap <cloud name> <controller name>
juju add-model <model name>
Then, either continue with the juju
client or use the terraform juju
client to deploy the PostgreSQL charm.
To deploy with the juju
client:
juju deploy postgresql-k8s --trust
See also:
juju deploy
command
To deploy with terraform juju
, follow the guide How to deploy using Terraform.
If you are not sure where to start or would like a more guided walkthrough for setting up your environment, see the Charmed PostgreSQL K8s tutorial.
Clouds
The guides below go through the steps to install different cloud services and bootstrap them to Juju:
How to deploy on multiple availability zones (AZ) demonstrates how to deploy a cluster on a cloud using different AZs for high availability.
Special deployments
These guides cover some specific deployment scenarios and architectures.
External network access
See How to connect from outside the local network for guidance on connecting with a client application outside PostgreSQL’s Kubernetes cluster.
Airgapped
How to deploy in an offline or air-gapped environment goes over the special configuration steps for installing PostgreSQL in an airgapped environment via CharmHub and the Snap Store Proxy.
Cluster-cluster replication
Cluster-cluster, cross-regional, or multi-server asynchronous replication focuses on disaster recovery by distributing data across different servers.
The Cross-regional async replication guide goes through the steps to set up clusters for cluster-cluster replication, integrate with a client, and remove or recover a failed cluster.
