latest/stable 128 05 Jun 2025
latest/edge 133 12 Dec 2025
3.0/stable 128 01 Aug 2025
3.0/edge 131 01 Aug 2025
2.0/stable 26 30 Jul 2025
2.0/edge 123 01 Apr 2025
1.0/edge 12 17 Oct 2023
juju deploy openfga-k8s --channel edge
The OpenFGA charmed Operator provides integrations to the Canonical Observability Stack.
In this reference we will provide a technical description of the alert rules, and the dashboards the OpenFGA operator passes to the components of the COS. We will also showcase the Metrics we use to provide observability features.
See more: Charmhub | OpenFGA > Integrations > metrics-endpoint, grafana-dashboard
Metrics
up
Description
When this counter equals one, that means the instance the metric was scraped from is available to the Prometheus deployment. If the counter equals zero, or the metric is not present, then the application is inaccessible to the Prometheus deployment.
Source
Prometheus
Intended
This metric signals whether a unit is unavailable. By specifying the label juju_unit this metric tells you whether the unit is available to the Prometheus component or not.
Example: up{juju_unit="openfga-k8s/0"}
Observed
  • Alert Rules: Rules in group OpenFGAUnavailable
  • Dashboard: OpenFGA Unit Availability
level
Description
All OpenFGA logs have a level, to indicate the seriousness of an event. OpenFGA logs (and json formatted logs in general) can be filtered by log levels.
Source
Loki
Usage
Use the LogQL’s abilities to enumerate log entries that match a regex template, and to parse json logs and populate fields such as level. Example: {juju_charm="openfga"} | json | level =~ `error`
Observed
  • Alert Rules: Rules in group OpenFGAHighSeverityLog
  • Dashboard Visualisation: OpenFGA High Severity Log Entries
Alerts
Description
Alerts in this alert group are fired based on how many log entries with the log level of error, critical, or fatal have been created in the last five minutes.
Data
Loki
OpenFGAUnavailable-multiple
Description
More than one unit in a multi-unit deployment is inactive.
Observed
Multiple operator instances have encountered an issue from which they can not recover within a minute. Without other alerts suggesting otherwise, the alert also suggests that there is at least one healthy unit in the deployment.
Severity
Error, because while the service is still available, there is now potential for a critical scenario.
OpenFGAUnavailable-all
Description
No unit in the deployment is active.
Observed
None of the units in the deployment are active. The service is inaccessible.
Severity
Fatal. The service has failed, and can not recover without human intervention.
Dashboards
OpenFGA
Description
  • visualization for the number of log entries with levels error or above within 5 minutes spans.
  • visualization displaying the availability of OpenFGA units.
Associated
  • Alert rules in alert group OpenFGAHighSeverityLog.
  • Alert rules in alert group OpenFGAUnavailable.
Help improve this document in the forum (guidelines). Last updated 1 year, 8 months ago.
