Mimir Charmed Operator
2.17/stable 102 06 Jul 2026
Ubuntu 26.04
2.17/candidate 103 06 Aug 2026
Ubuntu 26.04
2.17/beta 103 06 Aug 2026
Ubuntu 26.04
2.17/edge 103 05 Aug 2026
Ubuntu 26.04
dev/edge 107 21 Aug 2026
Ubuntu 26.04
2/stable 96 07 Jul 2026
Ubuntu 24.04
2/candidate 96 01 Jul 2026
Ubuntu 24.04
2/beta 96 01 Jul 2026
Ubuntu 24.04
2/edge 96 30 Jun 2026
Ubuntu 24.04
1/stable 50 08 Jul 2025
1/candidate 50 26 Jun 2025
1/beta 50 10 Jun 2025
1/edge 50 14 May 2025
juju deploy mimir-worker-k8s --channel 2.17/stable
Mimir for Kubernetes clusters.
Mimir Worker K8s is a Juju charm that runs Grafana Mimir components on Kubernetes as part of a horizontally scalable deployment. It works together with the Mimir Coordinator charm, following the coordinated-workers pattern. It is a component of the Canonical Observability Stack (COS): https://documentation.ubuntu.com/observability
Each worker unit receives its configuration from the coordinator and executes one or more Mimir roles, enabling flexible scaling of individual components independently.
Key features:
  • Fine-grained role configuration: individual roles (compactor, distributor, ingester, querier, query-frontend, store-gateway, ruler, alertmanager, query-scheduler, overrides-exporter, flusher) or meta-roles (read, write, backend, all).
  • Horizontal scaling by adding more worker units with the desired role combination.
  • Automatic configuration received from the Mimir Coordinator via the mimir-cluster relation.
  • Persistent storage for data and recovery across container restarts.
