3.7/stable 244 06 Jul 2026
Ubuntu 26.04
3.7/candidate 248 11 Aug 2026
Ubuntu 26.04
3.7/beta 248 11 Aug 2026
Ubuntu 26.04
3.7/edge 248 10 Aug 2026
Ubuntu 26.04
dev/edge 260 29 Sep 2026
Ubuntu 26.04
2/stable 217 16 Mar 2026
Ubuntu 24.04
2/candidate 256 28 Aug 2026
Ubuntu 24.04
2/beta 256 28 Aug 2026
Ubuntu 24.04
2/edge 256 27 Aug 2026
Ubuntu 24.04
1/stable 199 08 Jul 2025
Ubuntu 20.04
1/candidate 207 07 Apr 2026
Ubuntu 20.04
1/beta 207 31 Mar 2026
Ubuntu 20.04
1/edge 207 22 Sep 2025
Ubuntu 20.04
juju deploy loki-k8s --channel 2/edge
        labels:
          model: "some-juju-model"
Dashboards
Metrics
Alert rules
For built-in alert rules,
  • Alert exprs are qualified with topology labels. This way, built-in alerts fire only for the particular charm they originated from.
  • Alert labels are enriched with topology labels. This is meant for convenient reading of a rendered alert when presented to an on-caller. The labels would also be visible in the alert’s rendered expr, but alert labels are more convenient to read.
  • Alert rules are NOT enriched with the unit label. This is because we wouldn’t want to replicated all rules per unit. Unit information is included in metric and log labels. Since alert rules are forwarded to prometheus/loki per related app, not unit, having multiple units does not result in prometheus having duplicated alerts per unit. If an alert was qualified with a unit (which one?), we wouldn’t get alerts from any other units.
  • Alert rules descriptions can use a {{ $labels.juju_unit }} macro in the alert’s annotations, which will be replaced with the unit name for better readability.
Logs
Traces
Additional notes
  • In the future, the grafana-agent charm may start exposing metrics and logs generated by its own workload, and those would be enriched by juju topology labels.
  • In the future, the cos-configuration charm may start exposing metrics and logs generated by its own workload, git-sync, and those would be enriched by juju topology labels.
  • In the future (2025) grafana-agent will be replaced by otlp-collector. The general data flow should remain unchanged.
Help improve this document in the forum (guidelines). Last updated 1 year, 11 months ago.
