Loki
- Canonical Observability
latest/stable | 187 | 01 Apr 2025 | |
latest/candidate | 190 | 01 Apr 2025 | |
latest/beta | 192 | 01 Apr 2025 | |
latest/edge | 194 | 03 Apr 2025 | |
latest/edge | 193 | 03 Apr 2025 | |
1.0/stable | 104 | 12 Dec 2023 | |
1.0/candidate | 104 | 22 Nov 2023 | |
1.0/beta | 104 | 22 Nov 2023 | |
1.0/edge | 104 | 22 Nov 2023 |
juju deploy loki-k8s --channel 1.0/edge
labels:
model: "some-juju-model"
Dashboards
Depending on whether the charm where the dashboards reside is related directly to grafana-k8s
, or whether the data flows through grafana-agent
or cos-proxy
, there are subtle differences in how the topology is injected.
Built-in dashboards are enriched with topology drop-downs. This allows filtering dashboard data by topology labels. You can opt out of this behaviour by calling a ._reinitialize_dashboard_data(inject_dropdowns=False)
method on the GrafanaDashboardProvider
relation wrapper object.
Incidental dashboards coming in from a git-repo via the cos-configuration
charm are left intact.
Charms relating through grafana-agent
(-k8s
or not)
When dashboards are forwarded through a grafana-agent
intermediary, the juju topology labels of the charm of origin are injected (and not grafana-agent
’s). Any subsequent chaining to additional grafana agent charms would leave the labels intact.
cos-proxy
will apply its own topology to the labels, as old LMA-provider units don’t implement the more modern interfaces that we would need to add topology to the telemetry.
Metrics
(-k8s
or not)
For grafana-agent
: any metrics coming from the principal charm will be tagged with the topology of the principal unit. The generic Linux metrics coming from the node exporter will be tagged with the grafana-agent unit topology.
For grafana-agent-k8s
: all metrics going through the charm are left unchanged.
cos-proxy
will apply its own topology to the metrics.
Alert rules
Alert rules are workload-specific and vary from charm to charm. For example, two different workloads can have an alert for “memory running out”, but with different thresholds. We need to qualify each alert rule with a different set of labels, so that when an expr
evaluates as true, it only fires for the intended metrics.
For built-in alert rules,
- Alert
expr
s are qualified with topology labels. This way, built-in alerts fire only for the particular charm they originated from. - Alert labels are enriched with topology labels. This is meant for convenient reading of a rendered alert when presented to an on-caller. The labels would also be visible in the alert’s rendered
expr
, but alert labels are more convenient to read. - Alert rules are NOT enriched with the
unit
label. This is because we wouldn’t want to replicated all rules per unit. Unit information is included in metric and log labels. Since alert rules are forwarded to prometheus/loki per related app, not unit, having multiple units does not result in prometheus having duplicated alerts per unit. If an alert was qualified with a unit (which one?), we wouldn’t get alerts from any other units. - Alert rules descriptions can use a
{{ $labels.juju_unit }}
macro in the alert’s annotations, which will be replaced with the unit name for better readability.
Incidental rule files coming in from a git-repo via the cos-configuration
charm are left untouched and forwarded as-they-are.
(-k8s
or not)
cos-proxy
will apply its own topology to the rules.
Logs
K8s charms can stream logs to loki using the charm lib. Behind the scenes this is accomplished using promtail
, and log streams are enriched with juju topology labels.
(-k8s
or not)
In grafana-agent
, logs scraped from files, such as /var/log
, will be tagged with the grafana-agent’s own topology, while logs coming from the snap’s slot will be tagged with the source unit’s topology.
In grafana-agent-k8s
, the charm will not modify the topology.
cos-proxy
will apply its own topology to the logs.
Traces
Any charm can stream traces to Tempo using the tracing
charm lib. Usually this is done by sending the traces to a grafana-agent
(soon to be replaced by the OTEL collector), which forwards them to the COS stack. The agent will be responsible to attach to any trace going through it the juju topology of the unit generating them, if known, or else its own (for uncharmed workloads).
Additional notes
- In the future, the
grafana-agent
charm may start exposing metrics and logs generated by its own workload, and those would be enriched by juju topology labels. - In the future, the
cos-configuration
charm may start exposing metrics and logs generated by its own workload,git-sync
, and those would be enriched by juju topology labels. - In the future (2025)
grafana-agent
will be replaced byotlp-collector
. The general data flow should remain unchanged.
