| 2/stable | 217 | Today | |
| 2/candidate | 217 | 13 Mar 2026 | |
| 2/beta | 217 | 13 Mar 2026 | |
| 2/edge | 217 | 11 Mar 2026 | |
| dev/edge | 216 | 21 Jan 2026 | |
| 1/stable | 199 | 08 Jul 2025 | |
| 1/candidate | 199 | 26 Jun 2025 | |
| 1/beta | 207 | 18 Sep 2025 | |
| 1/edge | 207 | 22 Sep 2025 |
juju deploy loki-k8s --channel dev/edge
These guides accompany you through the complete loki-k8s-operator operations lifecycle.
Integrating
The following documents describe common Loki integration patterns with charmed and external workloads as well as integration interfaces of Loki API.
- Integrating
- Integrate with external (non-charmed) workloads
- Using HTTP API
- Troubleshooting missing logs
- Forwarding charm logs
- Logging via Pebble Log Forwarding
