Loki
| 3.7/stable | 244 | 06 Jul 2026 | |
| 3.7/candidate | 248 | 11 Aug 2026 | |
| 3.7/beta | 248 | 11 Aug 2026 | |
| 3.7/edge | 248 | 10 Aug 2026 | |
| dev/edge | 261 | Yesterday | |
| 2/stable | 217 | 16 Mar 2026 | |
| 2/candidate | 256 | 28 Aug 2026 | |
| 2/beta | 256 | 28 Aug 2026 | |
| 2/edge | 256 | 27 Aug 2026 | |
| 1/stable | 199 | 08 Jul 2025 | |
| 1/candidate | 207 | 07 Apr 2026 | |
| 1/beta | 207 | 31 Mar 2026 | |
| 1/edge | 207 | 22 Sep 2025 |
juju deploy loki-k8s --channel 2/edge
These guides accompany you through the complete loki-k8s-operator operations lifecycle.
Integrating
The following documents describe common Loki integration patterns with charmed and external workloads as well as integration interfaces of Loki API.
- Integrating
- Integrate with external (non-charmed) workloads
- Using HTTP API
- Troubleshooting missing logs
- Forwarding charm logs
- Logging via Pebble Log Forwarding
