Loki
- Canonical Observability
latest/stable | 190 | 15 Apr 2025 | |
latest/candidate | 192 | 15 Apr 2025 | |
latest/beta | 194 | 15 Apr 2025 | |
latest/edge | 194 | 03 Apr 2025 | |
latest/edge | 193 | 03 Apr 2025 | |
1.0/stable | 104 | 12 Dec 2023 | |
1.0/candidate | 104 | 22 Nov 2023 | |
1.0/beta | 104 | 22 Nov 2023 | |
1.0/edge | 104 | 22 Nov 2023 |
juju deploy loki-k8s --channel 1.0/edge
These guides accompany you through the complete loki-k8s-operator
operations lifecycle.
Integrating
The following documents describe common Loki integration patterns with charmed and external workloads as well as integration interfaces of Loki API.
- Integrating
- Integrate with external (non-charmed) workloads
- Using HTTP API
- Troubleshooting missing logs
- Forwarding charm logs
- Logging via Pebble Log Forwarding
