Kubeflow
Channel Revision Published
latest/beta 430 30 Aug 2024
latest/edge 438 30 Jun 2025
1.10/stable 440 05 Aug 2025
1.10/candidate 441 05 Aug 2025
1.10/beta 433 24 Mar 2025
1.9/stable 432 03 Dec 2024
1.9/beta 420 19 Jul 2024
1.9/edge 431 03 Dec 2024
1.8/stable 414 22 Nov 2023
1.8/beta 411 22 Nov 2023
1.8/edge 413 22 Nov 2023
1.7/stable 409 27 Oct 2023
1.7/beta 408 27 Oct 2023
1.7/edge 407 27 Oct 2023
This guide describes how to upgrade Charmed Kubeflow (CKF) one minor version at a time. Upgrading the solution by more than one minor version to another is not supported, nor is it recommended.
Current stable version: 1.10
The latest version of CKF is compatible with Charmed MLflow 2.15. If you have Charmed MLflow 2.1 deployed, you should upgrade it to 2.15 by following this upgrade guide before upgrading Charmed Kubeflow.
Before the upgrade
Before upgrading CKF, you should do the following:
  • Make sure:
    • All pipeline runs are completed and there are no recurring runs enabled.
    • Katib experiments, training jobs and notebooks are not in progress or pending.
  • Back up any important data according to your organisation’s policies. For databases, MinIO bucket pipelines and ML metadata, refer to the backup guide for further details. For restoring that data, refer to the restore guide.
The backup guide above does not guarantee the backup of all Kubeflow resources, such as notebooks and profiles. Make sure to take the appropriate actions to avoid accidental data loss.
  • Record all charm versions, including revisions, in your existing CKF deployment. This can be done by running juju export-bundle.
Upgrade environment
Juju
The current stable version of CKF is supported on Juju 3.6. If needed, follow the instructions in order to upgrade the deployment. See Supported versions for more information.
Kubernetes
The current stable version of CKF requires a Kubernetes cluster of at least version 1.29. For a full list of supported versions, refer to Supported versions. Before upgrading to CKF, make sure this requirement is met.
Upgrade charms
To upgrade charms, you should follow the steps below in the proposed order.
Some charms may go to Blocked state during some steps of the upgrade process. Once the upgrade is completed, all charms should be green and in Active state.
Istio
The current stable version of CKF requires Istio 1.24, please follow the instructions below to upgrade the istio-pilot and istio-gateway charms to that version:
  1. Scale down the istio-ingressgateway application to 0:
juju scale-application istio-ingressgateway 0
  1. To make sure the istio-ingressgateway deployment is removed, run the following command. It should succeed by returning 0:
kubectl -n kubeflow get deploy istio-ingressgateway-workload 2> >(grep -q "NotFound" && echo $?)
  1. istio-pilot must be upgraded one minor version at a time. Upgrade istio-pilot charm to all intermediate versions until getting to the desired one.
Run each of the refresh commands separately and wait until the charm goes to Active state before running the next one:
Failing to upgrade the istio-pilot charm one minor version at a time may result in the deployment being in an unrecoverable state.
juju refresh istio-pilot --channel 1.23/stable
juju refresh istio-pilot --channel 1.24/stable
  1. Upgrade and scale up istio-ingressgateway charm:
juju refresh istio-ingressgateway --channel <target-version>/stable
juju scale-application istio-ingressgateway 1
If you encounter any issues during the upgrade, refer to Istio upgrade troubleshooting for more details.
Upgrade rest of the charms
Upgrade the rest of the charms to their current stable versions with juju refresh:
juju refresh admission-webhook --channel 1.10/stable
juju refresh argo-controller --channel 3.4/stable
juju refresh dex-auth --channel 2.41/stable
juju refresh envoy --channel 2.4/stable
juju refresh jupyter-controller --channel 1.10/stable
juju refresh jupyter-ui --channel 1.10/stable
juju refresh katib-controller --channel 0.18/stable
juju refresh katib-db-manager --channel 0.18/stable
juju refresh katib-ui --channel 0.18/stable
juju refresh kfp-api --channel 2.4/stable
juju refresh kfp-metadata-writer --channel 2.4/stable
juju refresh kfp-persistence --channel 2.4/stable
juju refresh kfp-profile-controller --channel 2.4/stable
juju refresh kfp-schedwf --channel 2.4/stable
juju refresh kfp-ui --channel 2.4/stable
juju refresh kfp-viewer --channel 2.4/stable
juju refresh kfp-viz --channel 2.4/stable
juju refresh knative-eventing --channel 1.16/stable
juju refresh knative-operator --channel 1.16/stable
juju refresh knative-serving --channel 1.16/stable
juju refresh kserve-controller --channel 0.14/stable
juju refresh kubeflow-dashboard --channel 1.10/stable
juju refresh kubeflow-profiles --channel 1.10/stable
juju refresh kubeflow-roles --channel 1.10/stable
juju refresh kubeflow-volumes --channel 1.10/stable
juju refresh metacontroller-operator --channel 4.11/stable
juju refresh mlmd --channel ckf-1.10/stable
juju refresh minio --channel ckf-1.10/stable
juju refresh oidc-gatekeeper --channel ckf-1.10/stable
juju refresh pvcviewer-operator --channel 1.10/stable
juju refresh tensorboard-controller --channel 1.10/stable
juju refresh tensorboards-web-app --channel 1.10/stable
juju refresh training-operator --channel 1.9/stable
Help improve this document in the forum (guidelines). Last updated 8 months ago.
