Kubeflow
- Cloud
Charmed Kubeflow (CKF) 1.7 Patch 1 is a patch release that includes bug fixes and feature enhancements, documented in the release notes. This guide shows how to upgrade from CKF 1.7 to 1.7 Patch 1.
Requirements
- An active and idle Charmed Kubeflow 1.7 deployment. This requires all charms in the bundle to be in that state.
- Access to the dashboard of the existing Charmed Kubeflow 1.7 deployment.
- Admin access to a Kubernetes cluster where the existing Charmed Kubeflow 1.7 is deployed.
- Tools:
kubectl
,juju
(version 2.x)
Contents:
- Do you need an upgrade?
- Before upgrade
- Upgrade Istio
- Before charms upgrade
- Upgrade charms
- Verify upgrade
Check on the charm revisions deployed in your cluster to determine if they’re outdated and are eligible for the upgrade. To find the current revisions of your charms, run:juju status
The Patch 1 release touched only a subset of charms in the Charmed Kubeflow bundle. Compare the revisions of your deployed charms to the revisions listed below. If your deployed charms have a smaller revision, then proceed with the upgrade.
charm | revision |
admission-webhook | 205 |
istio-pilot | 551 |
istio-gateway | 551 |
katib-controller | 282 |
katib-db-manager | 253 |
katib-ui | 267 |
kfp-api | 413 |
kfp-persistence | 407 |
kfp-profile-controller | 388 |
kfp-schedwf | 424 |
kfp-ui | 412 |
kfp-viewer | 424 |
kfp-viz | 394 |
knative-eventing | 224 |
knative-operator | 199 |
knative-serving | 224 |
kserve-controller | 267 |
seldon-controller-manager | 354 |
Before Charmed Kubeflow upgrade
Before upgrading Charmed Kubeflow it is recommended to do the following:
- Stop all Notebooks.
- Review any important data that needs to be backed up and perform backup procedures according to the policies of your organisation.
- Record all charm versions in existing Charmed Kubeflow deployment.
All upgrade steps should be performed in the kubeflow
model. If you haven’t already, switch to the kubeflow
model:
# switch to kubeflow model
juju switch kubeflow
Upgrade Istio
It is assumed that the deployed istio-pilot
and istio-ingressgateway
versions alongside Charmed Kubeflow 1.7 are 1.16.
- Remove the
application and the corresponding relation withistio-pilot
# remove relation and istio-ingressgateway application
juju remove-relation istio-pilot istio-ingressgateway
juju remove-application istio-ingressgateway
- Run the following command to ensure that the
application and all related resources are properly removed. If removal was successful, the command should succeed (return0
juju show-application istio-ingressgateway 2> >(grep -q "not found" && echo $?)
kubectl -n kubeflow get deploy istio-ingressgateway-workload 2> >(grep -q "NotFound" && echo $?)
Troubleshooting of removal of `istio-ingressgateway` application
WARNING: Removing application using --force
option should be the last resort. There could be potential stability issues if application is not shutdown cleanly.
If required, remove istio-ingressgateway
application with --force
option and remove istio-ingressgateway-workload
manually:
juju remove-application --force istio-ingressgateway
kubectl -n kubeflow delete deploy istio-ingressgateway-workload
- Upgrade
istio-pilot
charm.
juju refresh istio-pilot --channel 1.16/stable
Troubleshooting of Istio upgrade
Refer to this document for troubleshooting tips.
- Deploy
and add a relation betweenistio-pilot
andistio-gateway
# deploy istio-ingressgateway
juju deploy istio-gateway --channel 1.16/stable --trust --config kind=ingress istio-ingressgateway
juju relate istio-pilot istio-ingressgateway
Before charms can be upgraded, you need to enable trust on deployed charms (required).
Enable trust on deployed charms
Because of changes in the charm code, some charms in Charmed Kubeflow 1.7 have to be trusted by juju before the upgrade.
WARNING: Please note that if you do not execute juju trust
for these charms, you may encounter authorization errors. If that is the case, please refer to the Troubleshooting guide.
# enable trust on charms
juju trust katib-db-manager --scope=cluster
juju trust kfp-api --scope=cluster
Upgrade charms
To upgrade Charmed Kubeflow each charm needs to be refreshed. It is recommended to wait for each charm to finish its upgrade before proceeding with the next.
Depending on the original deployment of Charmed Kuberflow version 1.7, the refresh command will report that charm is up-to-date which indicates that there is no need to upgrade that particular charm.
Before running the refresh command these are the applications which you should scale down before proceeding.
juju scale-application admission-webhook 0
juju scale-application kfp-profile-controller 0
juju scale-application kfp-ui 0
juju scale-application kfp-viz 0
Lets proceed with the refresh commands. During the upgrade some charms can temporarily go into error
or blocked
state, but they should go active
after a while.
# upgrade charms
juju refresh admission-webhook --channel 1.7/stable
juju refresh katib-controller --channel 0.15/stable
juju refresh katib-db-manager --channel 0.15/stable
juju refresh katib-ui --channel 0.15/stable
juju refresh kfp-api --channel 2.0-alpha.7/stable
juju refresh kfp-persistence --channel 2.0-alpha.7/stable
juju refresh kfp-profile-controller --channel 2.0-alpha.7/stable
juju refresh kfp-schedwf --channel 2.0-alpha.7/stable
juju refresh kfp-ui --channel 2.0-alpha.7/stable
juju refresh kfp-viewer --channel 2.0-alpha.7/stable
juju refresh kfp-viz --channel 2.0-alpha.7/stable
juju refresh knative-eventing --channel 1.8/stable
juju refresh knative-operator --channel 1.8/stable
juju refresh knative-serving --channel 1.8/stable
juju refresh kserve-controller --channel 0.10/stable
juju refresh seldon-controller-manager --channel 1.15/stable
juju relate istio-pilot:gateway-info kserve-controller:ingress-gateway
Troubleshooting charm upgrade
If a charm fails to upgrade or is stuck in a maintenance
state for a long time it is possible to recover by running the refresh command with the version that was there prior to deployment, i.e. downgrade the charm. After that, repeat the upgrade.
Don’t forget to scale up.
juju scale-application admission-webhook 1
juju scale-application kfp-profile-controller 1
juju scale-application kfp-ui 1
juju scale-application kfp-viz 1
Verify upgrade
You can verify the progress of the upgrade by running
watch -c juju status --color
when all services are in active
/idle
state then the upgrade should be finished.
