Kubeflow
- Cloud
With Charmed Kubeflow, you can create Jupyter Notebook servers with Nvidia NGC images by following this guide.
Contents:
An active Charmed Kubeflow deployment. For installation instructions, follow the Get started tutorial.Deploy the dependencies
Deploy the charms required for Notebooks integration with NGC images.juju deploy ngc-integrator --channel=latest/edge --trust
juju deploy resource-dispatcher --channel=latest/edge --trust
Add the required relation between the deployed charms
juju relate ngc-integrator:pod-defaults resource-dispatcher:pod-defaults
Wait until the charms are in active
status, which can be monitored with:
juju status --watch 5s
Create a Notebook with NGC
From the Notebooks UI:-
select
new Notebook
to go to the Notebook creation page -
Click on
Custom Notebook
then chooseAdvanced Options
Select
Custom Image
and type in the full name of the NGC image. In the example below, the image isnvcr.io/nvidia/pytorch:23.09-py3
Scroll down to the bottom of the Notebook creation page and click on
Advanced Options
From the
Configurations
dropdown, selectEnable Nvidia NGC JupyterLab Notebook
as shown below
Finally, launch the Notebook server and connect to it. Now you have a Jupyter Notebook server with an NGC image!
