Kubeflow
- Cloud
Applies to Kubeflow 1.8 and above.
The Kubeflow Dashboard provides easy access to all of Kubeflow’s components. This dashboard can be customised to add or remove Kubeflow tools or link to your own content.
The Kubeflow Dashboard has four categories of links:
menu
and quick
links always point to links inside Kubeflow (specifically, inside the Kubeflow ingress Gateway). They are specified as links relative to the Kubeflow Gateway, for example /volumes
for the Kubeflow Volumes page. These links will open inside the Kubeflow Dashboard UI (the left and top menu bars will remain). Typically, both menu
and quick
links point to pieces of kubeflow, where by convention menu
links point to high level components (Volumes
, Notebooks
) and quick
links point to something specific (a particular Kubeflow Pipelines experiment). Both links could, however, point to anything hosted on the same Gateway, such as a custom tool integrated into your Kubeflow deployment.
external
and documentation
links always point to links outside Kubeflow, such as https://charmed-kubeflow.io
. These links open in a separate tab, not in the Kubeflow Dashboard UI. By convention, external
links generally point to high level components (ex: your own container registry), whereas documentation
links point to documentation.
Out of the box, Charmed Kubeflow’s Dashboard includes links to the core Kubeflow applications. Links can be added and reordered to customize the experience.
