Kubeflow
  • Kubeflow Charmers | bundle
  • Cloud
Channel Revision Published
latest/beta 430 30 Aug 2024
latest/edge 423 26 Jul 2024
1.9/stable 432 03 Dec 2024
1.9/beta 420 19 Jul 2024
1.9/edge 431 03 Dec 2024
1.10/beta 433 24 Mar 2025
1.8/stable 414 22 Nov 2023
1.8/beta 411 22 Nov 2023
1.8/edge 413 22 Nov 2023
1.7/stable 409 27 Oct 2023
1.7/beta 408 27 Oct 2023
1.7/edge 407 27 Oct 2023
This guide describes how to use Azure Kubernetes Service (AKS) Spot Virtual Machines (VMs) with Charmed Kubeflow (CKF). Spot virtual machines are an easy way to access extra computing on demand that can be leveraged for specific Machine Learning (ML) training.
You should use spot VMs for your workflows that are not time-sensitive and short tests and experiments where stability is less important than cost. For example, data processing, distributed training and hyperparameter tuning, model training and batch inference.
It is not recommended to use spot VMs for the Kubernetes control plane, notebooks and dashboards, databases or datastores like Minio, and model serving for online inference.
Setting up nodes is intended for system admins. Configuring and running workloads is intended for end users.
Requirements
  • CKF deployed on an AKS cluster. See Deploy to AKS for more details.
Note that GPU- accelerated VMs are only available in certain regions which may differ from your chosen AKS cluster region.
Add an Azure spot node pool to AKS
  1. Go to the Charmed Kubeflow AKS cluster overview page.
  2. Click on Node pools under the Settings dropdown on the left-hand sidebar.
  3. Click on Add node pool.
  4. In the next section, make sure to check the Enable Azure Spot instances check box.
  5. Configure the Azure spot virtual machine by clicking on Configure….
Configure your Azure spot virtual machine
Eviction type and policy
You can specify when your VMs are evicted and how. If your workload has a maximum price over which it is not worth running it, you can define it in this section. See Understand eviction for more details.
VMs size and pricing
You can define the size and pricing of your VMs based on your workloads.
Labels
Labels identify the VM(s) that belong to a certain pool. It is recommended to add at least one label to better identify your VMs later on.
  1. Click on Add on the bottom left side of the page once your spot node pool is configured.
Run workflows in spot virtual machines
To schedule workloads, you have to assign their associated Pod(s) to the desired VM(s).
To do so, you have to configure your workloads. This configuration depends entirely on the workload type and the component that runs it. See the following examples.
Please make sure you follow Azure’s suggestions for adding tolerations and affinities using the examples below.
Pipelines
Using the kfp v2 SDK
You can use the kfp v2 SDK to add a node selector constraint. To do so, use the following configuration:
import kfp
from kfp import dsl
def gpu_p100_op():
    return dsl.ContainerOp(
        name='check_p100',
        image='tensorflow/tensorflow:latest-gpu',
        command=['sh', '-c'],
        arguments=['nvidia-smi']
    ).add_node_selector_constraint('cloud.my-cloud.com/gpu-accelerator', ‘accelerator-name’).container.set_gpu_limit(1)
Training jobs
When using YAMLs
You can modify training job yaml representations to have node selectors or affinity. See training jobs for more details.
A training job usually has different processes, such as the “Chief”, “Worker”, or “Parameter Server”. Each of them has their own spec, where node affinity or node selectors can be defined, provided that a spot virtual machine is labelled.
For example, you can define a TFJob yaml representation as follows:
apiVersion: kubeflow.org/v1
kind: TFJob
metadata:
  generateName: tfjob
  namespace: your-user-namespace
spec:
  tfReplicaSpecs:
    PS:
        spec:
    Worker:
        spec:
Using nodeAffinity
To add nodeAffinity to a training job you can edit the specific process or processes’ spec field ensuring to match matchExpressions with the spot node pool:
Worker:
  spec:
    affinity:
	  nodeAffinity:
    	    requiredDuringSchedulingIgnoredDuringExecution:
              nodeSelectorTerms:
    	      - matchExpressions:
      	        - key: a-custom-key.io/my-key
        	  operator: In
        	  values:
        	  - a-custom-value
Using nodeSelector
You can add a nodeSelector to ensure specific processes are scheduled in the desired node pool as follows:
Worker:
  spec:
    containers:
    - name: my-training-process
      image: training:0.1
    nodeSelector:
      a-custom-key.io/my-key: a-custom-value
When using the SDK
When using the kubeflow.training SDK in a Notebook, for example, the training job can be edited similar to how the pure yaml would be. That’s because the training jobs use the Python Kubernetes Client to define each component.
Creating a TFJob requires you to do the following:
container = V1Container(...)
worker = V1ReplicaSpec(..., spec=V1PodSpec(containers=container))
tfjob = KubeflowOrgV1TFJob(
    api_version="kubeflow.org/v1",
    kind="TFJob",
    metadata=V1ObjectMeta(name="mnist",namespace=namespace),
    spec=KubeflowOrgV1TFJobSpec(
        clean_pod_policy="None",
        tf_replica_specs={"Worker": worker}
Based on the above, to schedule the worker process in a spot virtual machine, the v1PodSpec object has to have either a nodeAffinity or nodeSelector. For example:
    spec=V1PodSpec(containers=container),
    affinity=V1Affinity(...)
Katib hyperparameter tuning
When using YAMLs
You can schedule a Katib hyperparameter tuning experiment to a specific VM by adding nodeAffinity or nodeSelectors.
These fields should be added to the yaml representation of the experiment, at the trialSpec level.
Using nodeAffinity
    trialSpec:
      apiVersion: batch/v1
      kind: Job
      spec:
        template:
          spec:
            containers:
              - name: training-container
                image: image-name
                command:
                  - "a-command"
            affinity:
              nodeAffinity:
                  nodeSelectorTerms:
                  - matchExpressions:
                       operator: In
                       values:
                       - a-custom-value
            restartPolicy: Never
Using nodeSelector
  trialSpec:
  kind: Job
    spec:
      containers:
         image: training:0.1
      nodeSelector:
See Trial Templates for more information.
When using the SDK
When using the kubeflow.katib SDK in a Notebook, for example, the experiment can be edited similar to how the pure yaml would be. That’s because the trial worker spec is usually defined as a JSON template of a Kubernetes Job:
trial_spec={
    "apiVersion": "batch/v1",
    "kind": "Job",
    "spec": {
        "template": {
            "metadata": {
                "annotations": {
            "spec": {
                "containers": [...]
                "restartPolicy": "Never"
This is where nodeAffinity or a nodeSelector could be added to ensure this workload is scheduled in the desired spot virtual machine.
Best practices for evicting workloads from a spot virtual machine
These are a few recommendations for handling workloads eviction from spot VMs:
  • Set terminationGracePeriodSeconds to allow the workloads to terminate gracefully. For instance, if you have access to the yaml representation of a workload, you can do the following:
spec:
  nodeSelector:
    my-key.io/key: "value"
    terminationGracePeriodSeconds: 25
  • Configure the processes to finalise gracefully by modifying the code. For example, the kfp SDK offers the set_retry() method for setting retries.
