Kubeflow
- Cloud
Deploying Charmed Kubeflow on MicroK8s behind a web proxy requires some configuration. The target machine’s environment must be prepared to handle the web proxy prior to deployment. Additionally, Kubeflow components must be configured to work with the web proxy.
Contents:
Prepare your environment
Before you get to Installing Charmed Kubeflow, first you need to set up your client with proxy setttings, and install Microk8s and Juju with proxy configurations.Snap
- Save the value of your proxy server address (PROXY) for reuse
PROXY=http://<username>:<password>@<proxy IP>:<proxy port>/
The proxy IP and proxy port are usually given by your network administrator
Add the username:<password>@
part only if the proxy server is configured with credentials, check with your network administrator.
- Set the snap proxy settings
sudo snap set system proxy.http=$PROXY
sudo snap set system proxy.https=$PROXY
This will enable you to install snap packages
- Restart snap service
sudo systemctl restart snapd.service
Microk8s
- Install Microk8s:
sudo snap install microk8s --classic --channel=1.29/stable
- Add the current user to the Microk8s group:
sudo usermod -a -G microk8s $USER
newgrp microk8s
This way you don’t have to use sudo
for every Microk8s command.
- Enable microk8s add-ons needed to run Charmed Kubeflow. Note that the metallb range can change depending on the use case and the env, but we use this one in all our guides.
microk8s enable dns:$(resolvectl status | grep "Current DNS Server" | awk '{print $NF}') # This sets the dns to your current nameserver
microk8s enable storage ingress metallb:10.64.140.43-10.64.140.49
- Get the values
cluster-cidr
andservice-cluster-ip-range
stored in/var/snap/microk8s/current/args/kube-proxy
and/var/snap/microk8s/current/args/kube-apiserver
respectively, and store these values in a variable.
cat /var/snap/microk8s/current/args/kube-proxy | grep cluster-cidr
# Sample output
--cluster-cidr=<cluster cidr> # copy this value for the next command
CLUSTER_CIDR=<cluster cidr>
cat /var/snap/microk8s/current/args/kube-apiserver | grep service-cluster-ip-range
# Sample output
-service-cluster-ip-range=<service cluster ip range> # copy this value for the next command
SERVICE_CIDR=<service cluster ip range>
You will need these two values in the next step and later when installing Juju.
See more: Microk8s | Installing behind a proxy
- Get the Internal IP of the nodes where your cluster is running, you can check that by running:
microk8s kubectl get nodes -o wide
Take note of the INTERNAL-IP
value.
Save the IP(s) in a variable with suffix /24
, comma-separated if you have a multi-node cluster.
NODE_IP=<nodes internal ip(s)>/24
- Set the proxy settings in
containerd-env
. Modify thecontainerd-env
file located in${SNAP_DATA}/args/containerd-env
(normally/var/snap/microk8s/current/args/containerd-env
HTTPS_PROXY=http://<username>:<password>@<proxy IP>:<proxy port>/
NO_PROXY=<cluster-cidr>,<service-cluster-ip-range>,<nodes internal ip(s)>/24,127.0.0.1
- Restart the
microk8s
snap to pick up the changes:
sudo snap restart microk8s
- Check that Microk8s is running with the desired add-ons
microk8s status
#sample output:
microk8s is running
high-availability: no
datastore master nodes: 127.0.0.1:19001
datastore standby nodes: none
addons:
enabled:
dns # (core) CoreDNS
ha-cluster # (core) Configure high availability on the current node
hostpath-storage # (core) Storage class; allocates storage from host directory
ingress # (core) Ingress controller for external access
metallb # (core) Loadbalancer for your Kubernetes cluster
storage # (core) Alias to hostpath-storage add-on, deprecated
Juju
- Export the system proxy settings used by the Juju client. Make sure to set the metallb as you configured it when installing Microk8s.
Make sure to replace
<hostname>
with your own hostname.
export http_proxy=$PROXY
export https_proxy=$PROXY
export no_proxy=$CLUSTER_CIDR,\
$SERVICE_CIDR\
127.0.0.1,\
$NODE_IP,\
<hostname>,\
.svc,\
.local,\
10.64.140.0/24,\ # This is the metallb IP range
.nip.io
- Install Juju
- Create a Juju controller in your Microk8s cluster and set the proxy model default values. Change the metallb value if you configured it differently.
juju bootstrap microk8s uk8s --model-default juju-http-proxy=$PROXY \
--model-default juju-https-proxy=$PROXY \
--model-default juju-no-proxy=$CLUSTER_CIDR,\
$SERVICE_CIDR\
127.0.0.1,\
$NODE_IP,\
<hostname>,\ # replace with your own hostname
.svc,\
.local,\
10.64.140.0/24 # This is the metallb IP range
- Add Juju model
juju add-model kubeflow # model name must be kubeflow
- Make sure
Kubeflow
model has your proxy settings, run:
juju model-config
You should see the proxy settings in the juju-http-proxy
, juju-https-proxy
, and juju-no-proxy
variables.
Deploy Charmed Kubeflow
- Deploy Kubeflow bundle
juju deploy kubeflow --channel 1.7/stable --trust
Watch the progress and wait until all charms are up
watch -c juju status --color
- Configure the dashboard URL and credentials. Follow the steps from the Get started tutorial.
- Check if you can access the dashboard URL
curl -I http://10.64.140.43.nip.io --noproxy '*'
You should see a 302 Found
response similar to this:
HTTP/1.1 302 Found
location: http://10.64.140.43.nip.io/dex/auth?client_id=authservice-oidc&redirect_uri=%2Fauthservice%2Foidc%2Fcallback&response_type=code&scope=openid+profile+email+groups&state=MTY3OTY2MTYwOXxFd3dBRURWaE9EUnFha3ByZDNwRWEyZzVhREk9fBanXjJZJn5xKjDyvnrMc83mpkCyOt6ATbR0oox_Ppqm
date: Fri, 24 Mar 2023 12:40:09 GMT
x-envoy-upstream-service-time: 482
server: istio-envoy
transfer-encoding: chunked
Use the components behind a proxy
Before you dive into the Charmed Kubeflow components, make sure you know the necessary component configurations for a proxy environment.Notebooks
Apply the following poddefault to your user namespace so each notebook you create will have proxy configurations set. TheNO_PROXY
and no_proxy
values would be the same as you configured in the Juju model.
cat <<EOF | kubectl apply -n $USER_NAMESPACE -f -
apiVersion: kubeflow.org/v1alpha1
kind: PodDefault
metadata:
spec:
desc: Add proxy settings
env:
- name: HTTP_PROXY
value: http://10.0.1.119:3128/ # replace with $PROXY
- name: http_proxy
- name: HTTPS_PROXY
- name: https_proxy
- name: NO_PROXY
value: <cluster cidr>,<service cluster ip range>,127.0.0.1,<nodes internal ip(s)>/24,<cluster hostname>,.svc,.local
- name: no_proxy
selector:
matchLabels:
notebook-proxy: "true"
EOF
You should now be able to see Add proxy settings
when creating a new notebook under Advanced Options > Configurations
. Always select that option.
Katib
Before running a Katib experiment, add your proxy envs to your experiment definition for each container underspec.trialTemplate.trialSpec.spec.template.spec.containers
env:
- name: HTTP_PROXY
- name: http_proxy
- name: HTTPS_PROXY
- name: https_proxy
Expand to see full Katib experiment example
apiVersion: kubeflow.org/v1beta1
kind: Experiment
metadata:
spec:
objective:
type: maximize
goal: 0.99
objectiveMetricName: Validation-accuracy
additionalMetricNames:
- Train-accuracy
algorithm:
algorithmName: grid
parallelTrialCount: 1
maxTrialCount: 1
maxFailedTrialCount: 1
parameters:
- name: lr
parameterType: double
feasibleSpace:
min: "0.001"
max: "0.01"
step: "0.001"
- name: num-layers
parameterType: int
feasibleSpace:
min: "2"
max: "5"
- name: optimizer
parameterType: categorical
feasibleSpace:
list:
- sgd
- adam
- ftrl
trialTemplate:
primaryContainerName: training-container
trialParameters:
- name: learningRate
description: Learning rate for the training model
reference: lr
- name: numberLayers
description: Number of training model layers
reference: num-layers
- name: optimizer
description: Training model optimizer (sdg, adam or ftrl)
reference: optimizer
trialSpec:
apiVersion: batch/v1
kind: Job
spec:
template:
metadata:
annotations:
sidecar.istio.io/inject: "false"
spec:
containers:
- name: training-container
image: docker.io/kubeflowkatib/mxnet-mnist:latest
command:
- "python3"
- "/opt/mxnet-mnist/mnist.py"
- "--batch-size=64"
- "--lr=${trialParameters.learningRate}"
- "--num-layers=${trialParameters.numberLayers}"
- "--optimizer=${trialParameters.optimizer}"
env:
- name: HTTP_PROXY
- name: http_proxy
- name: HTTPS_PROXY
- name: https_proxy
restartPolicy: Never
Pipelines
If your pipeline needs to download data or pull an image, you can inject your proxy envs into a pipeline from inside a notebook with the kfp sdk as done in this example notebook.Istio
If you’re having trouble accessing the Charmed Kubeflow components, you might need to configure proxy settings for Istio.kubectl apply -n kubeflow -f - <<EOF
apiVersion: networking.istio.io/v1beta1
kind: ServiceEntry
metadata:
spec:
hosts:
- my-company-proxy.com # ignored
addresses:
- 10.0.1.119/32 # replace with proxy IP
ports:
- number: 3128 # replace with proxy port
protocol: TCP
EOF
