Kubeflow
- Cloud
This guide shows how to connect your laptop to a VM using SSH and port forwarding. The setup is specifically targeted at those running our Charmed Kubeflow or Charmed MLflow with Kubeflow tutorials.
With this setup you will be able to:
- Access the application UI through your web browser
- Access the VM through a terminal
These steps assume the following:
- You are using Ubuntu 22.04 or later.
- VM access will be secured via a private key stored in ~/.ssh/myKey.pem, and the connection will be to ubuntu@myserver.cloudomain.com. You will need to tweak these details accordingly for your specific use case.
Contents:
Setup
To setup an SSH tunnel with a SOCKS proxy, follow these steps:
Use the ssh
command to open an SSH tunnel
For Charmed Kubeflow run this command:
ssh -i ~/.ssh/myKey.pem -D 9999 ubuntu@myserver.cloudomain.com
For Charmed MLflow run this command:
ssh -i ~/.ssh/myKey.pem -L 31380:localhost:31380 -D 9999 ubuntu@myserver.cloudomain.com
Note: for MLflow you’ll see the additional
option. This forwards localhost port31380
to the remote machine, because we need this to access the MLflow dashboard.
Configure your Ubuntu network settings to use a SOCKS proxy
On your laptop’s network settings:
- Open
Settings > Network > Network Proxy
. - Set the network proxy to ‘Manual’.
- Set the SOCKS host to:
127.0.0.1
and port9999
Note: Once this is done, all your network traffic will go through the SSH tunnel to the VM. If the SSH tunnel is closed, then you’ll lose internet.
Deactivate
To deactivate this setup, first revert your network settings by disabling the network proxy, then close the SSH tunnel.
