We've discontinued the registration of new Bundles
New Bundle registrations are no longer accepted. Existing bundles remain functional. We recommend using the Juju Terraform Provider for new deployments.
Kubeflow
Kubeflow Charmers Publisher | bundle
Channel Revision Published
latest/beta 430 30 Aug 2024
latest/edge 438 30 Jun 2025
1.10/stable 447 19 Feb 2026
1.10/candidate 448 19 Feb 2026
1.10/beta 442 28 Jan 2026
1.10/edge 442 28 Jan 2026
1.11/stable 450 15 Apr 2026
1.11/candidate 449 03 Mar 2026
1.11/beta 452 17 Aug 2026
1.11/edge 445 18 Feb 2026
1.9/stable 432 03 Dec 2024
1.9/beta 420 19 Jul 2024
1.9/edge 431 03 Dec 2024
1.8/stable 414 22 Nov 2023
1.8/beta 411 22 Nov 2023
1.8/edge 413 22 Nov 2023
1.7/stable 409 27 Oct 2023
1.7/beta 408 27 Oct 2023
1.7/edge 407 27 Oct 2023
juju deploy kubeflow --channel 1.9/beta
This guide describes the general steps required to install Charmed Kubeflow (CKF).
CKF can be installed on any CNCF certified Kubernetes (K8s), including Canonical Kubernetes, AKS, EKS, GKE, Openshift, and any kubeadm-deployed cluster.
Requirements
Charmed Kubeflow requires a running K8s cluster with the following:
Bootstrap Juju
CKF is deployed to Kubernetes with Juju. Before deployment, Juju must be bootstrapped to the K8s cluster. For bootstrapping instructions, see Get started with Juju.
Create the kubeflow model
To create a Juju model for CKF, run:
juju add-model kubeflow
The model name must be kubeflow.
See Juju OLM | add-model for more details.
Deploy CKF
To deploy the most recent stable version of CKF, run:
juju deploy kubeflow --trust
You can install a different version of CKF by using the --channel option. See Supported versions for more details.
It may take up to 20 minutes for all charms to become active.
You can monitor the deployment status with Juju as follows:
juju status --watch 5s
Access CKF dashboard
You can interact with CKF using its central dashboard, accessed through an IP address. To access it, you must:
  1. Configure Dex to authenticate with the Identity Provider of your choice.
  2. Find the dashboard’s IP address.
Configure Dex
To configure Dex’s built-in connector, set credentials by configuring dex-auth with a username and a password:
juju config dex-auth static-username=<new username>
juju config dex-auth static-password=<new password>
To use an external Identity Provider, see Integrate with identity providers for more details.
Find the dashboard IP address
If the deployment uses a LoadBalancer, you can find the dashboard’s IP by running the following command:
kubectl -n kubeflow get svc istio-ingressgateway-workload -o jsonpath='{.status.loadBalancer.ingress[0].ip}'
See kubectl get for more details.
If you have configured Istio Gateway to use a different gateway service type such as ClusterIP or NodePort, the dashboard should be accessible at that service’s IP. See Istio Gateway configurations for more information.
If DNS is required, use the resolvable address from istio-ingressgateway.
To access the dashboard remotely, you can obtain the IP over SSH and a SOCKS proxy. See How to set up SSH for more details.
Log in
Once you have accessed the dashboard IP address, log in using the credentials matching the identity provider you are using.
Help improve this document in the forum (guidelines). Last updated 1 year, 6 months ago.
