Kubeflow
Channel Revision Published
latest/beta 430 30 Aug 2024
latest/edge 438 30 Jun 2025
1.10/stable 440 05 Aug 2025
1.10/candidate 441 05 Aug 2025
1.10/beta 433 24 Mar 2025
1.9/stable 432 03 Dec 2024
1.9/beta 420 19 Jul 2024
1.9/edge 431 03 Dec 2024
1.8/stable 414 22 Nov 2023
1.8/beta 411 22 Nov 2023
1.8/edge 413 22 Nov 2023
1.7/stable 409 27 Oct 2023
1.7/beta 408 27 Oct 2023
1.7/edge 407 27 Oct 2023
The Autoscaling model serving solution offers the ability to deploy KServe, Knative, and Istio charms on their own to serve Machine Learning (ML) models that can be accessed through ingress.
Requirements
  • Juju 2.9.49 or above.
  • A Kubernetes cluster with a configured LoadBalancer, DNS, and a storage class solution.
Deploy the solution
You can deploy the solution in the following ways:
  1. Deploy with Terraform.
  2. Deploy with charm bundle.
Regardless of the chosen deployment method, the following charm configuration is required:
juju config knative-serving istio.gateway.namespace="<Istio ingress gateway namespace>"
where the Istio ingress gateway namespace corresponds to the model name where the autoscaling-model-serving bundle is deployed.
The Autoscaling model serving is defined with a Terraform module that facilitates its deployment using the Terraform Juju provider. See Terraform Juju provider for more details.
In its most basic form, the solution can be deployed as follows:
terraform apply -v
Refer to this for more information about inputs and outputs of the module.
Charm bundles are now obsolete, but as part of v0.1, the bundle.yaml file is still available. To deploy:
  1. Clone the autoscaling-model-serving repository.
  2. Deploy using the bundle.yaml file:
juju deploy ./bundle/bundle.yaml --trust
Perform inference
  1. Apply an InferenceService.
Kserve offers a simple example in steps 1, 2, and 3.
  1. Perform inference by making a request using the URL from the recently created InfercenceService.
For example, by running:
kubectl get inferenceservices <name of the inferenceservice> -n <namespace where it is deployed>
You get the following output:
NAME       	URL                                             	READY   PREV   LATEST   PREVROLLEDOUTREVISION   LATESTREADYREVISION                	AGE
<name>   http://<name>.<namespace>.<LoadBalancer IP.DNS>     	True       	100
The http://<name>.<namespace>.<LoadBalancer IP.DNS> can be used in any sort of request, for example:
$ curl -v -H "Content-Type: application/json" http://<name>.<namespace>.<LoadBalancer IP.DNS>/v1/models/<name>:predict -d @./some-input.json
Integrate with COS
You can integrate the solution with Canonical Observability Stack (COS) while deploying with the Terraform module by running:
terraform apply -var cos_configuration=true
If the solution was deployed using the charm bundle, or using the Terraform module without the COS options passed, see Integrate with COS for more details.
Help improve this document in the forum (guidelines). Last updated 8 months ago.
