Kubeflow
- Cloud
In Charmed Kubeflow, object storage access can be achieved with MinIO. Access via MinIO requires some special configuration. It is relevant for local workstations as well as private cloud deployments.
See more: Charmhub | MinIO
Contents:
- Configure the keys for MinIO
- Create the “allow-minio.yaml” file
- Configure the “allow-minio.yaml” file
- Refresh Juju
First, check if the access key is configured:
juju config minio access-key
Then, check if the secret key is configured:
juju config minio secret-key
In case they are set, please remember the set credentials. Otherwise, please go ahead and set a new username and password:
juju config minio access-key=<username>
juju config minio secret-key=<password>
Please bear in mind that both username and password need to have a minimum of 8 characters.
See also: Juju OLM |
juju config
, Charmhub >minio
> Configure
In order to gain access to MinIO, it has to be added to the pod and configured. In order to do that, a YAML needs to be created and configured.
In the terminal, please run: touch allow-minio.yaml
After that, please run: nano allow-minio.yaml
Once the “allow-minio.yaml” file opens, please update the information within it as below:apiVersion: kubeflow.org/v1alpha1
kind: PodDefault
metadata:
spec:
desc: Allow access to Minio
selector:
matchLabels:
access-minio: "true"
env:
- name: AWS_ACCESS_KEY_ID
valueFrom:
secretKeyRef:
key: accesskey
optional: false
- name: AWS_SECRET_ACCESS_KEY
valueFrom:
secretKeyRef:
key: secretkey
optional: false
- name: MINIO_ENDPOINT_URL
value: http://minio.kubeflow.svc.cluster.local:9000
Please save it and then close it.
After that, please run in the terminal the following command:
kubectl apply -f allow-minio.yaml -n <user-namespace>
Refresh Juju
In the terminal please runjuju refresh –kubeflow
After that, you should be able to access Minio. If you would like to check if it is added to the model, please run it in the terminal.
sudo microk8s kubectl get PodDefault -n admin
There you should see “allow-minio”
Another option is to access the MinIO dashboard. By doing this you need to run juju status
and take the IP address of MinIO <>. Go to your browser, where you already set up the Proxy for Kubeflow and enter it. In order to login, please use the username and password that you previously set.
