Jenkins K8s
latest/stable 201 29 Sep 2025
Ubuntu 24.04 Ubuntu 22.04
latest/stable 200 29 Sep 2025
latest/edge 311 20 Apr 2026
latest/edge 310 20 Apr 2026
juju deploy jenkins-k8s --channel edge
How to integrate with external agent charms
We consider any agent charm to be external when they don’t have layer 3 connectivity with the jenkins-k8s charm. To integrate with those agent charms, we’ll leverage the jenkins-k8s charm’s agent-discovery-ingress integration.
The agent-discovery-ingress integration can be used with any charm that supports the :ingress interface. One example is the traefik-k8s charm.
juju integrate jenkins-k8s:agent-discovery-ingress traefik-k8s:ingress
Agents considered external have to be integrated using a cross-model integration. To integrate with such agent, simply integrate with the ingress provider charm as mentioned above and then integrate with the agent charm’s offer endpoint.
juju integrate jenkins-k8s:agent <offer-endpoint>
Networking considerations
The charm assumes that:
  1. There are connectivity between the Juju controller of the jenkins-k8s charm and the Juju controller of the agent charm trying to connect with the jenkins-k8s charm.
  2. The agent can resolve the ingress host name provided by the jenkins-k8s charm and the resulting IP address is reachable, and there are firewall rules in place to allow HTTP traffic.
  3. In case a reverse proxy is present, it is also expected that the HTTP connection coming from the agent charm is allowed to be upgraded into a WebSocket connection. The reverse proxy should also be configured with a suitable idle timeout for WebSocket connections to avoid intermittent agent disconnection.
Help improve this document in the forum (guidelines). Last updated 7 months ago.
