Jenkins agent k8s
- By Canonical IS DevOps
latest/stable | 25 | 01 Feb 2024 | |
latest/edge | 25 | 01 Feb 2024 |
juju deploy jenkins-agent-k8s --channel edge
Integrations
agent
Interface: jenkins_agent_v0
Supported charms: jenkins
Agent integration is a required relation for the Jenkins agent charm to supply the job execution output to Jenkins.
Example agent integrate command: juju integrate jenkins jenkins-agent-k8s
