24.04 22.04 20.04
0.44/stable 824 07 Jul 2026
0.44/stable 831 07 Jul 2026
0.44/stable 816 07 Jul 2026
0.44/stable 828 07 Jul 2026
0.44/stable 829 07 Jul 2026
0.44/stable 833 07 Jul 2026
0.44/stable 832 07 Jul 2026
0.44/stable 827 07 Jul 2026
0.44/stable 830 07 Jul 2026
0.44/stable 825 07 Jul 2026
0.44/stable 826 07 Jul 2026
0.44/candidate 893 11 Aug 2026
0.44/candidate 895 11 Aug 2026
0.44/candidate 896 11 Aug 2026
0.44/candidate 897 11 Aug 2026
0.44/candidate 898 11 Aug 2026
0.44/candidate 878 07 Aug 2026
0.44/candidate 880 07 Aug 2026
0.44/candidate 875 07 Aug 2026
0.44/candidate 876 07 Aug 2026
0.44/candidate 872 06 Aug 2026
0.44/candidate 825 07 Jul 2026
0.44/beta 893 11 Aug 2026
0.44/beta 895 11 Aug 2026
0.44/beta 896 11 Aug 2026
0.44/beta 897 11 Aug 2026
0.44/beta 898 11 Aug 2026
0.44/beta 878 07 Aug 2026
0.44/beta 880 07 Aug 2026
0.44/beta 875 07 Aug 2026
0.44/beta 876 07 Aug 2026
0.44/beta 872 06 Aug 2026
0.44/beta 825 07 Jul 2026
0.44/edge 898 10 Aug 2026
0.44/edge 897 10 Aug 2026
0.44/edge 896 10 Aug 2026
0.44/edge 895 10 Aug 2026
0.44/edge 893 10 Aug 2026
0.44/edge 880 06 Aug 2026
0.44/edge 878 06 Aug 2026
0.44/edge 876 06 Aug 2026
0.44/edge 875 06 Aug 2026
0.44/edge 872 05 Aug 2026
0.44/edge 825 07 Jul 2026
dev/edge 952 29 Aug 2026
dev/edge 951 29 Aug 2026
dev/edge 950 29 Aug 2026
dev/edge 949 29 Aug 2026
dev/edge 948 29 Aug 2026
dev/edge 947 29 Aug 2026
dev/edge 946 29 Aug 2026
dev/edge 945 29 Aug 2026
dev/edge 936 27 Aug 2026
dev/edge 929 27 Aug 2026
dev/edge 925 26 Aug 2026
2/stable 851 07 Jul 2026
2/stable 846 07 Jul 2026
2/stable 850 07 Jul 2026
2/stable 849 07 Jul 2026
2/stable 848 07 Jul 2026
2/stable 847 07 Jul 2026
2/candidate 851 18 Jun 2026
2/candidate 846 18 Jun 2026
2/candidate 850 18 Jun 2026
2/candidate 849 18 Jun 2026
2/candidate 848 18 Jun 2026
2/candidate 847 18 Jun 2026
2/beta 851 18 Jun 2026
2/beta 846 18 Jun 2026
2/beta 850 18 Jun 2026
2/beta 849 18 Jun 2026
2/beta 848 18 Jun 2026
2/beta 847 18 Jun 2026
2/edge 851 17 Jun 2026
2/edge 850 17 Jun 2026
2/edge 849 17 Jun 2026
2/edge 848 17 Jun 2026
2/edge 847 17 Jun 2026
2/edge 846 17 Jun 2026
1/stable 606 18 Sep 2025
1/stable 605 18 Sep 2025
1/stable 607 18 Sep 2025
1/stable 603 18 Sep 2025
1/stable 604 18 Sep 2025
1/stable 602 18 Sep 2025
1/candidate 606 09 Sep 2025
1/candidate 605 09 Sep 2025
1/candidate 607 09 Sep 2025
1/candidate 603 09 Sep 2025
1/candidate 604 09 Sep 2025
1/candidate 602 09 Sep 2025
1/beta 606 02 Sep 2025
1/beta 605 02 Sep 2025
1/beta 607 02 Sep 2025
1/beta 603 02 Sep 2025
1/beta 604 02 Sep 2025
1/beta 602 02 Sep 2025
1/edge 607 20 Aug 2025
1/edge 606 20 Aug 2025
1/edge 605 20 Aug 2025
1/edge 604 20 Aug 2025
1/edge 603 20 Aug 2025
1/edge 602 20 Aug 2025
juju deploy grafana-agent --channel dev/edge
Sometimes applications are instrumented with more metrics than we want to afford, from a resources perspective. In such cases we can choose to selectively drop some metrics before they are ingested.
Discover high-cardinality metrics
Prometheus’s /tsdb-status endpoint is quite handy for discovering high cardinality metrics you may want to drop prior to ingestion.
In this guide, we will show how to drop all the go_gc_* metrics. To check how many go_gc_* metrics you currently have, run the following query:
count by (__name__) ({__name__=~"go_gc_.+"})
Means for dropping metrics
Metrics can be dropped by using the drop action in several different places:
  • Under <scrape_config> section (<metric_relabel_configs> subsection). For example: all the self-monitoring scrape jobs that e.g. COS Lite has in place.
  • Under <remote_write> section (<write_relabel_configs> subsection). For example: prometheus can be told to drop metrics before pushing them to another prometheus over remote-write API. This use case is not addressed in this guide.
Drop metrics via metric name in scrape config
Charms that integrate with prometheus or grafana agent, provide a “scrape config” to MetricsEndpointProvider (imported from charms.prometheus_k8s.v0.prometheus_scrape).
Let’s take for example the alertmanager self-metrics that prometheus scrapes. If we do not want prometheus or grafana agent to ingest any go_gc_* metrics from alertmanager, then we need to adjust the scrape job specified in the alertmanager charm:
diff --git a/src/charm.py b/src/charm.py
index fa3678c..f0e943b 100755
--- a/src/charm.py
+++ b/src/charm.py
@@ -250,6 +250,13 @@ class AlertmanagerCharm(CharmBase):
             "scheme": metrics_endpoint.scheme,
             "metrics_path": metrics_path,
             "static_configs": [{"targets": [target]}],
+            "metric_relabel_configs": [
+                    "source_labels": ["__name__"],
+                    "regex": "go_gc_.+",
+                    "action": "drop",
         return [config]
Drop metrics via the scrape-config charm
In a typical scrape-config deployment such as:
graph LR
some-external-target --- scrape-target --- scrape-config --- prometheus
We can specify the drop action via a config option for the scrape-config charm:
$ juju config sc metric_relabel_configs="$(cat <<EOF
- source_labels: ["__name__"]
  regex: "go_gc_.+"
  action: "drop"
EOF
References
