The Charm Store will undergo scheduled database maintenance on July 5, 2026 22:00 to July 6, 02:00 UTC. During this time, you may be unable to access charm and bundle metadata or publish updates. No user action is required and services will automatically resume once maintenance is complete.
Generic Exporter
dev/edge 58 05 Mar 2026
Ubuntu 24.04 Ubuntu 22.04
dev/edge 57 05 Mar 2026
dev/edge 56 05 Mar 2026
dev/edge 55 05 Mar 2026
dev/edge 54 05 Mar 2026
dev/edge 53 05 Mar 2026
dev/edge 52 05 Mar 2026
dev/edge 51 05 Mar 2026
juju deploy generic-exporter-operator --channel dev/edge
Integrate with COS
This guide explains how to integrate the Generic Exporter operator with the Canonical Observability Stack (COS) by using the Opentelemetry Collector machine charm as the telemetry collector.
Requirements
  • A Juju controller managing:
    • A machine model where your principal application, the Generic Exporter operator, and the Opentelemetry Collector machine charm will run.
    • A Kubernetes model where COS Lite (Prometheus, Loki, Grafana, etc.) is deployed.
  • COS Lite up and running according to the COS documentation.
  • Your principal application and the Generic Exporter operator are already deployed and related (as in the tutorial).
Deploy COS Lite
Follow the official COS Lite documentation to deploy COS on a Kubernetes cluster (for example, MicroK8s):
This will give you a model (for example, cos) containing prometheus-k8s, loki-k8s, grafana-k8s, alertmanager-k8s, catalogue-k8s and traefik-k8s.
Deploy Opentelemetry Collector (machine)
In your machine model, deploy the Opentelemetry Collector machine charm:
juju switch applications
juju deploy opentelemetry-collector --channel=2/stable
Relate the Opentelemetry Collector to your principal application (if appropriate) so it can collect host-level metrics and logs. For a simple ubuntu principal:
juju integrate opentelemetry-collector ubuntu
Opentelemetry Collector will run as a subordinate on the same machines as your principal units.
Relate Generic Exporter to Opentelemetry Collector
The Generic Exporter operator uses the cos-agent relation and the cos_agent library to forward metrics and alert rules to the Opentelemetry Collector.
Relate the applications:
juju integrate generic-exporter-operator opentelemetry-collector
This informs Opentelemetry Collector about:
  • The scrape job (target address, port, path) for the exporter
  • The on-disk directory where alert rule files are written (for example, /run/node-exporter-0/alerts.yaml)
The Opentelemetry Collector, in turn, forwards metrics and alerts to COS Lite via prometheus_remote_write and loki_push_api relations, per the COS integration tutorial.
Relate Opentelemetry Collector to COS
From the Kubernetes model running COS Lite, expose Opentelemetry Collector’s remote write and logging interfaces as offers, or follow the standard “instrument machine charms” tutorial to connect Opentelemetry Collector to COS Lite:
For example:
# In the COS model
juju switch cos
juju offer prometheus-k8s:receive-remote-write prom-remote-write
juju offer loki-k8s:logging loki-logging
# In the machine model
juju consume <controller>/cos.prom-remote-write
juju consume <controller>/cos.loki-logging
juju integrate opentelemetry-collector prom-remote-write
juju integrate cpentelemetry-collector loki-logging
Refer to the latest COS Lite and Opentelemetry Collector machine documentation for the exact relation names and topology.
Verify metrics and alerts in COS
Once all relations are established:
  1. Confirm that all units are active:
    juju status
  2. In the COS Grafana dashboard:
    • Search for a Prometheus job corresponding to the app name you chose (for example, node-exporter).
    • Confirm that the alert rules you attached (see next how-to) appear under Alerting → Rules, with topology labels derived from the exporter and principal charms.
If metrics or alerts do not appear, check:
  • The Generic Exporter unit status (it may be Blocked if the metrics endpoint is not reachable).
  • Opentelemetry Collector relations to COS Lite (juju status opentelemetry-collector).
