Canonical Observability Stack Proxy
- By Canonical Observability
latest/stable | 72 | 26 Mar 2024 | |
latest/candidate | 76 | 24 Apr 2024 | |
latest/beta | 76 | 10 Apr 2024 | |
latest/edge | 76 | 06 Apr 2024 | |
1.0/stable | 54 | 16 Feb 2024 | |
1.0/candidate | 54 | 12 Dec 2023 | |
1.0/beta | 54 | 12 Dec 2023 | |
1.0/edge | 54 | 12 Dec 2023 |
juju deploy cos-proxy --channel 1.0/edge
Juju topology labels are telemetry labels that are used for identifying the origin of metrics and logs in juju models. In other words, the Juju topology labels are a fingerprint of a unit in some juju model that is emitting telemetry. Especially when you have hundreds, thousands of nodes, it is essential to be able to locate that one unit that has been emitting alerts. For this reason, Juju topology labels play a key role in the Canonical observability stack (COS).
labels:
model: "some-juju-model"
The COS charm libraries wrapping the observability relation endpoints inject these labels into any outgoing metric, log, trace, and dashboard, so that the charm using them doesn’t have to be aware of this at all. Any charm can ship with dashboards and (alert) rules and integrations with COS to monitor its lifecycle. These are the so-called “built-in” dashboards and rules. These are workload-specific. As the charm is deployed and related to COS, the charm libraries mediating said integration automatically inject the juju topology labels in all built-in dashboards and rules.
Dashboards
Depending on whether the charm where the dashboards reside is related directly to grafana-k8s
, or whether the data flows through grafana-agent
or cos-proxy
, there are subtle differences in how the topology is injected.
Built-in dashboards are enriched with topology drop-downs. This allows filtering dashboard data by topology labels. You can opt out of this behaviour by calling a ._reinitialize_dashboard_data(inject_dropdowns=False)
method on the GrafanaDashboardProvider
relation wrapper object.
Incidental dashboards coming in from a git-repo via the cos-configuration
charm are left intact.
Charms relating through grafana-agent
(-k8s
or not)
When dashboards are forwarded through a grafana-agent
intermediary, the juju topology labels of the charm of origin are injected (and not grafana-agent
’s). Any subsequent chaining to additional grafana agent charms would leave the labels intact.
TODO: what happens to dashboards via cos-proxy
Alert rules
For built-in alert rules,
- Alert
expr
s are qualified with topology labels. This way, built-in alerts fire only for that particular unit - Alert labels are enriched with topology labels. This is meant for convenient reading of a rendered alert when presented to an on-caller. The labels would also be visible in the alert’s rendered
expr
, but alert labels are more convenient to read. - Alert rules are NOT enriched with the
unit
label, because alert rules are forwarded to prometheus/loki per related app, not unit. I.e. having multiple units does not result in prometheus having duplicated alerts per unit. If an alert was qualified with a unit (which one?), we wouldn’t get alerts from any other units.
Incidental rule files coming in from a git-repo via the cos-configuration
(-k8s
or not)
TODO: what happens to rule files via cos-proxy
Logs
K8s charms can stream logs to loki using the charm lib. Behind the scenes this is accomplished using promtail
, and log streams are enriched with juju topology labels.
(-k8s
or not)
TODO: what happens to logs via grafana agent
TODO: what happens to logs via cos-proxy
Additional notes
- In the future, the
grafana-agent
charm may start exposing metrics and logs generated by its own workload, and those would be enriched by juju topology labels. - In the future, the
cos-configuration
charm may start exposing metrics and logs generated by its own workload,git-sync
