Vault
latest/edge 89 31 Jan 2024
Ubuntu 22.04 Ubuntu 20.04
latest/edge 9 27 Jan 2023
2.0/stable 590 06 Oct 2026
Ubuntu 24.04
2.0/candidate 590 02 Sep 2026
Ubuntu 24.04
2.0/beta 590 02 Sep 2026
Ubuntu 24.04
2.0/edge 605 Today
Ubuntu 24.04
2.0/edge 604 Yesterday
Ubuntu 24.04
2.0/edge 603 Yesterday
Ubuntu 24.04
1.19/stable 578 14 Jul 2026
Ubuntu 24.04
Ubuntu 24.04
1.19/beta 578 14 Jul 2026
Ubuntu 24.04
1.19/edge 579 13 Jul 2026
Ubuntu 24.04
1.19/edge 578 13 Jul 2026
Ubuntu 24.04
1.18/stable 591 07 Oct 2026
Ubuntu 24.04
Ubuntu 24.04
1.18/beta 591 10 Sep 2026
Ubuntu 24.04
1.18/edge 591 10 Sep 2026
Ubuntu 24.04
1.17/stable 354 11 Apr 2025
Ubuntu 24.04
Ubuntu 24.04
1.17/beta 383 14 Jul 2025
Ubuntu 24.04
1.17/edge 491 12 Jan 2026
Ubuntu 24.04
1.16/stable 502 20 Feb 2026
1.16/beta 502 19 Feb 2026
1.16/edge 502 19 Feb 2026
1.15/stable 248 24 Jul 2024
1.15/beta 248 24 Jul 2024
1.15/edge 248 10 Jul 2024
juju deploy vault-k8s --channel latest/edge
Connecting to Vault
