Vault
| 2.0/edge | 605 | 16 Oct 2026 | |
| 2.0/edge | 604 | 15 Oct 2026 | |
juju deploy vault-k8s --channel 1.17/edge
Use Vault as an ACME Server to obtain TLS certificates
In this how-to guide, we will configure Vault to act as an ACME server using Vault’s PKI secrets engine. Here self-signed-certificates will be the parent CA.
The certificates issued by Vault will have a validity period that is half of its intermediate CA’s, which is determined by the root provider’s configuration, in this case, the self-signed certificates.
- Configure Vault’s common name
juju config vault common_name=mydomain.com
- Deploy the parent CA
juju deploy self-signed-certificates --channel 1/stable
- Integrate Vault with its parent CA
juju integrate vault:tls-certificates-acme self-signed-certificates
Now the ACME server is accessible on https://<Vault Address>:8200/v1/charm-acme/acme/directory
Now you should be able to obtain a certificate from Vault using an ACME client, for example Lego.
