Vault
| 2.0/edge | 604 | Yesterday | |
| 2.0/edge | 603 | Yesterday | |
| 2.0/edge | 602 | Yesterday | |
juju deploy vault-k8s --channel 1.18/edge
Unseal a sealed unit
In the circumstance that a Vault unit restarts, you will have to manually unseal it. This guide walks you through the necessary steps:
Starting from a cluster where one unit is sealed:
$ juju status
demo microk8s-localhost microk8s/localhost 3.4.0 unsupported 13:02:12-04:00
vault waiting 3 vault-k8s 1.15/beta 198 10.152.183.208 no installing agent
vault/0* active idle 10.1.182.38
vault/1 active idle 10.1.182.51
vault/2 blocked idle 10.1.182.15 Please unseal Vault
Set the VAULT_ADDR variable to the sealed unit:
export VAULT_ADDR=https://$(juju status vault/2 --format=yaml | yq '.applications.vault.units.vault/2.address'):8200; echo $VAULT_ADDR
Unseal the the unit using the same unseal keys as received during the initialization of the Vault leader:
vault operator unseal -tls-skip-verify EJoB62t286mjUpSQYZg3mOla3lz/bbElVL5OLnj+rpE=
The units will go back to the active/idle state:
$ juju status
demo microk8s-localhost microk8s/localhost 3.4.0 unsupported 13:03:26-04:00
vault active 3 vault-k8s 1.15/beta 198 10.152.183.208 no
vault/2 active idle 10.1.182.15
