Vault
latest/edge 89 31 Jan 2024
Ubuntu 22.04 Ubuntu 20.04
latest/edge 9 27 Jan 2023
2.0/stable 590 06 Oct 2026
Ubuntu 24.04
2.0/candidate 590 02 Sep 2026
Ubuntu 24.04
2.0/beta 590 02 Sep 2026
Ubuntu 24.04
2.0/edge 605 16 Oct 2026
Ubuntu 24.04
2.0/edge 604 15 Oct 2026
Ubuntu 24.04
2.0/edge 603 15 Oct 2026
Ubuntu 24.04
1.19/stable 578 14 Jul 2026
Ubuntu 24.04
Ubuntu 24.04
1.19/beta 578 14 Jul 2026
Ubuntu 24.04
1.19/edge 579 13 Jul 2026
Ubuntu 24.04
1.19/edge 578 13 Jul 2026
Ubuntu 24.04
1.18/stable 591 07 Oct 2026
Ubuntu 24.04
Ubuntu 24.04
1.18/beta 591 10 Sep 2026
Ubuntu 24.04
1.18/edge 591 10 Sep 2026
Ubuntu 24.04
1.17/stable 354 11 Apr 2025
Ubuntu 24.04
Ubuntu 24.04
1.17/beta 383 14 Jul 2025
Ubuntu 24.04
1.17/edge 491 12 Jan 2026
Ubuntu 24.04
1.16/stable 502 20 Feb 2026
1.16/beta 502 19 Feb 2026
1.16/edge 502 19 Feb 2026
1.15/stable 248 24 Jul 2024
1.15/beta 248 24 Jul 2024
1.15/edge 248 10 Jul 2024
juju deploy vault-k8s --channel 1.19/beta
Restore a backup
Pre-requisites
To restore a Vault Backup, ensure you:
  • Have a Vault cluster deployed.
  • Your Vault deployment is in active idle state.
  • Have access to S3 storage where your backup is saved.
  • Have configured the settings for S3 storage.
  • Have access to the unseal keys and root-token used by the Vault cluster at the time of creating the backup.
Once the prerequisites are in place you can run the restore-backup action on the leader unit to restore the specified backup, providing the following parameters to the action:
  • backup-id: Identifier of the backup you are attempting to restore, as saved on the S3 storage.
juju run vault/leader restore-backup backup-id=<backup-id>
The restored Vault will be unsealed and it will require to be unsealed an authorised using root token and unseal key that were in use at the time of creating the backup.
List backups
You can get a list of the identifiers of all the backups that are stored on the configured S3 storage using the list-backups action:
juju run vault/leader list-backups
Restore Backups created in different environments
To restore a snapshot that wasn’t created using the Vault charm’s create-backup action, you’ll need to manually upload it to the S3 storage accessible by the Vault charm where the restore-backup action will run.
  1. Configure the settings for S3 storage.
  2. Connect to your S3 storage
  3. Use the same bucket configured in step 1 to store the snapshot
  4. Use the ID of the stored snapshot to run the restore backup action
Help improve this document in the forum (guidelines). Last updated 1 year, 11 months ago.
