Vault
latest/edge 89 31 Jan 2024
Ubuntu 22.04 Ubuntu 20.04
latest/edge 9 27 Jan 2023
2.0/stable 590 06 Oct 2026
Ubuntu 24.04
2.0/candidate 590 02 Sep 2026
Ubuntu 24.04
2.0/beta 590 02 Sep 2026
Ubuntu 24.04
2.0/edge 605 Yesterday
Ubuntu 24.04
2.0/edge 604 15 Oct 2026
Ubuntu 24.04
2.0/edge 603 15 Oct 2026
Ubuntu 24.04
1.19/stable 578 14 Jul 2026
Ubuntu 24.04
Ubuntu 24.04
1.19/beta 578 14 Jul 2026
Ubuntu 24.04
1.19/edge 579 13 Jul 2026
Ubuntu 24.04
1.19/edge 578 13 Jul 2026
Ubuntu 24.04
1.18/stable 591 07 Oct 2026
Ubuntu 24.04
Ubuntu 24.04
1.18/beta 591 10 Sep 2026
Ubuntu 24.04
1.18/edge 591 10 Sep 2026
Ubuntu 24.04
1.17/stable 354 11 Apr 2025
Ubuntu 24.04
Ubuntu 24.04
1.17/beta 383 14 Jul 2025
Ubuntu 24.04
1.17/edge 491 12 Jan 2026
Ubuntu 24.04
1.16/stable 502 20 Feb 2026
1.16/beta 502 19 Feb 2026
1.16/edge 502 19 Feb 2026
1.15/stable 248 24 Jul 2024
1.15/beta 248 24 Jul 2024
1.15/edge 248 10 Jul 2024
juju deploy vault-k8s --channel latest/edge
Recover a Vault Cluster When Raft Quorum is Lost
  1. A Vault cluster that has lost quorum
1. Scale the Cluster Down to One Node
On the machine charm, this means removing all but one unit. Ideally, keep the unit that is the leader, but otherwise choose any healthy unit that is in the blocked “Waiting for vault to finish raft leader elecetion” state.
juju remove-unit vault/1 vault/2 vault/3 vault/4
You may need to use a combination of --force and --no-wait to remove units if they are in a bad state.
On the Kubernetes charm, you can scale the deployment down using the scale-applicaiton command.
juju scale-application vault-k8s 1
2. Run the bootstrap-raft Action
Next, run the bootstrap-raft action on the remaining unit. This will re-bootstrap the cluster with a single node.
juju run vault/leader bootstrap-raft
This should update the status of the unit to “Please unseal Vault”.
3. Unseal Vault
If necessary, follow the instructions on how to unseal Vault in the Unseal a sealed unit guide.
4. Scale the Cluster Back Up
Once the single unit is unsealed, you can scale the cluster back up to the desired number of units (and unseal if necessary)
On the Machine charm:
juju add-unit vault -n 4
Or, on the Kubernetes charm:
juju scale-application vault-k8s 5
Help improve this document in the forum (guidelines). Last updated 1 year, 8 months ago.
