Superset Operator
| latest/stable | 39 | 30 Apr 2025 | |
| latest/edge | 69 | 24 Jul 2026 | |
| 6/stable | 68 | 10 Jul 2026 | |
| 6/edge | 68 | 10 Jul 2026 | |
| 5/stable | 48 | 26 Nov 2025 | |
| 5/edge | 48 | 21 Nov 2025 |
juju deploy superset-k8s --channel 6/edge
Charmed Superset supports the following feature flags:
| Feature flag | Default value | Description |
| DASHBOARD_CROSS_FILTERS | true | Enables cross-filtering on dashboard charts. |
| DASHBOARD_RBAC | true | Enables role-based access control (RBAC) for dashboards. |
| EMBEDDABLE_CHARTS | true | Allows charts to be embedded in external websites or applications. |
| SCHEDULED_QUERIES | true | Enables the scheduling of queries to run at regular intervals. |
| ESTIMATE_QUERY_COST | true | Provides an estimate of the query cost before execution. |
| ENABLE_TEMPLATE_PROCESSING | true | Enables processing of templates within SQL queries for dynamic generation. |
| GLOBAL_ASYNC_QUERIES | false | Allows queries to run asynchronously across multiple instances globally. |
You can enable, True, and disable, False, these flags using the following command:
juju config superset-k8s-ui <flag-name>=<True/False>
