Self Signed X.509 Certificates
latest/stable 264 11 Mar 2025
latest/stable 265 11 Mar 2025
latest/edge 634 22 Apr 2026
latest/edge 633 22 Apr 2026
1/stable 588 05 Mar 2026
Ubuntu 24.04 Ubuntu 22.04
1/stable 585 05 Mar 2026
1/stable 586 05 Mar 2026
1/candidate 588 05 Mar 2026
1/candidate 585 05 Mar 2026
1/candidate 586 05 Mar 2026
1/beta 587 05 Mar 2026
1/beta 588 05 Mar 2026
1/beta 586 05 Mar 2026
1/beta 585 05 Mar 2026
1/edge 707 30 Sep 2026
1/edge 706 30 Sep 2026
1/edge 705 30 Sep 2026
1/edge 704 30 Sep 2026
1/edge 327 31 Jul 2025
juju deploy self-signed-certificates --channel 1/edge
If you have the charm deployed from the latest/stable track we recommend migrating to 1/stable immediately as latest is deprecated.
To keep using your current CA follow these steps:
  1. Rename the secret owned by self-signed-certificates that contains the CA from ca-certificates to active-ca-certificates
juju update-secret <secret-id> --name active-ca-certificates
  1. Refresh the charm using the following config options
  • Set root-ca-validity and certificate-validity to match the values from your current deployment, for example if you had certificate-validity set to 10 now you need to set it to 10d
  • ca-country-name to US as it was a default value in latest
juju refresh ssc --channel 1/edge --config certificate-validity=10d --config root-ca-validity=365d --config ca-country-name="US"
If keeping the current CA is not a concern:
juju refresh ssc --channel 1/stable
  1. Configure the charm with your desired config values (This step is essential for issued certificates to be rotated and new certificates to be issued by the new CA)
For example:
juju config ssc certificate-validity=30d
Or rotate the private key if no config changes are desired
juju run ssc/0 rotate-private-key
Help improve this document in the forum (guidelines). Last updated 10 months ago.
