Prometheus
| 2/stable | 287 | 16 Mar 2026 | |
| 2/candidate | 287 | 13 Mar 2026 | |
| 2/beta | 287 | 13 Mar 2026 | |
| 2/edge | 287 | 13 Mar 2026 | |
| dev/edge | 291 | 16 Apr 2026 | |
| 1/stable | 247 | 14 May 2025 | |
| 1/candidate | 247 | 14 May 2025 | |
| 1/beta | 247 | 14 May 2025 | |
| 1/edge | 247 | 14 May 2025 |
juju deploy prometheus-k8s --channel dev/edge
One of the design decisions for COS was to pack alert rules together with the corresponding charmed operator. The alert rules are sent to Prometheus over relation data. This means you cannot opt-out of the packed alert rules. However, sometimes the same charm is used for different deployments (and customers), requiring different thresholds on alert rules.
Manually modifying the rules file in the charm container wouldn’t do the trick, as the file would be rewritten with the original values on some lifecycle events.
Let’s explore some solutions to this problem.
Remove the alert rule from the charmed operator
Truth is, if a charm has an alert rules with a threshold that may change across deployed instances, it probably shouldn’t be bundled with the charm.
Generalize the alert rule
One possible solution to this issue is to generalize the alert rules, so it can be used across all deployments: maybe there’s some other metric or expression correlated to the one the alert refers to, which is a better candidate for the alert rule.
For example, let’s consider an alert related to power consumption: power_watts > 10. Power requirements can however change drastically between deployments; some ideas to try to alter the expression and make it more generic:
- perhaps what you really care about is watt-hours, and that’s a threshold that might remain constant;
- maybe you want the power to not exceed a mean-variance envelope compared to the past 2 hours.
If you can rewrite the alert in a way that’s generic enough for all deployments, you should modify the alert rule in the charm.
Note: central-host-health-alerts exist in cos-lib and are “injected” for deployments including Prometheus
Use cos-config
For deployment-specific rules, you can use the cos-config charm; it allows you to “side load” rules in a git-ops style from a git repository, where you could store specific alert rules for a specific deployment.
